Egr Delete Pipe Q
Old Oct 29, 2007 | 08:54 PM
bcfordguy's Avatar
bcfordguy
Egr Delete Pipe Q
Will there be any problems if i put the egr delete pipe in? stock no tunner
Old Oct 29, 2007 | 09:27 PM
Todder's Avatar
Todder
I believe if your stock and you delete it you will have a CEL light on.
Time for a SCT!
Old Oct 29, 2007 | 09:53 PM
hangon2me's Avatar
hangon2me
I have no problems with mine. Stock program no chip or programmer. Nice up grade highly recommend. 2004-2003 I am sure you will throw CEL light.
Old Oct 29, 2007 | 11:12 PM
rcpcanada's Avatar
rcpcanada
I installed a block off plate on my 04, no cel!
Old Oct 30, 2007 | 11:45 AM
2004SUPERDUTY's Avatar
2004SUPERDUTY
what are the advatages of blocking the egr? also how much is involved in doing this?
Old Oct 30, 2007 | 08:31 PM
rcpcanada's Avatar
rcpcanada
Here's my story.....Truck was in for head gaskets. While it was in I did some reasearch on this subject. I talked with a gentleman from Elite who said it would be foolish not to install an egr block off plate while the cab was off. (2004) This is my thinking.....How pissed would I be if my truck still puked after installing new gaskets and studs? Insallation of this product should solve any flash boiling issues. Performance gains aside useing a block off or a sneaky pipe on 05-07 models along with studs should almost guarantee that my truck will not puke, even while tuned. I think my truck has less lag now but after not driving the truck for the 2 weeks it was in the shop it's hard to tell. One thing I can say for sure is that the motor is not as loud as it was before. Hope this helps.........
Old Oct 31, 2007 | 07:31 AM
HeavyAssault's Avatar
HeavyAssault
Depending on the MY truck you may get a CEL and code with the EGR deleted. An SCT will "cure" the EGR CEL by removing the actual EGR operation from the PCM.
I have found the truck responds better when moving from a stop or while on the highway.
Installing a modded up-pipe isn't too difficult, you just need about 2-3 hours (max) and some basic hand tools. Some have found removing the passenger side wheel well liner helps. You should remove the downpipe to have better access as well.
Old Apr 1, 2010 | 09:08 AM
patrickke's Avatar
patrickke
I know this is an old post but what all is involved in doing this? is their anything that is disconnected and needs to be reconnected once I do this? anyone have pics of this being done? What is involved in doing the sneaky pipe? does anything else need to be blocked off?
Old Apr 1, 2010 | 09:46 AM
HeavyAssault
I replied to your PM.
Deanp88
6.4L Power Stroke Diesel
Feb 8, 2017 10:13 PM
Morgan_drake13
Nov 26, 2016 03:08 PM
6OhPowestroke
Aug 24, 2016 06:14 PM
Freighttrain
Nov 18, 2013 09:27 PM
rotun
Dec 5, 2007 09:58 PM
