Sinister EGR delete
Old Feb 8, 2012 | 08:30 AM
samiott's Avatar
samiott
Sinister EGR delete
Anyone installed the Sinister EGR delete on a 6.0? I just recently installed one of these and I have a hiss under the hood. I am not sure if I have an air leak or if it is just the sound of different airflow from eliniating the EGR and the air flowing through the delete pipe. The delete pipe looks like its a chrome pipe instead of the old iron looking pipe I replaced.
Old Feb 8, 2012 | 08:55 AM
Curt's05's Avatar
Curt's05
Wiser by FTE
I had the same hissing, it was the ebp tube was loose @ the sensor...
Old Feb 8, 2012 | 09:35 AM
samiott's Avatar
samiott
ah cool. hopefully its something that simple. I'll take a look when I get home from work today.
Thanks!
Old Feb 8, 2012 | 04:09 PM
npccpartsman's Avatar
npccpartsman
Probably the y-pipe connection at the back of the turbo.
Old Feb 8, 2012 | 06:03 PM
samiott's Avatar
samiott
man I hope not but I have a feeling you are right. That clamp is a huge Pain in the ...
Haven't had a chance to look at it yet. Probably be tomorrow.
Old Feb 8, 2012 | 10:21 PM
BLADE35's Avatar
BLADE35
Odds are if you just installed an egr deleate and the Hiss started at the same time you have a Exhaust leak somewhere maybe the Ypipe or at the exhaust manafold where the uppipe connects
when cold start it up and feel around all the connections really fast or hang a string on a stick and watch for it to blow around
Did you install the exhaust pipe gaskets that came with the kit at the joints
Im betting on the ypipe probably has a leak where it connects to the turbo
Old Feb 9, 2012 | 08:20 AM
Striderwv's Avatar
Striderwv
IIRC you also may have a small hairline crack(s) in the y pipe.
Zimmatic
6.4L Power Stroke Diesel
Aug 30, 2018 09:53 AM
Special Ed
Feb 2, 2012 12:44 AM
rotun
Dec 5, 2007 09:58 PM
03strokinfl
Sep 24, 2007 09:30 AM
jrs_big_ford_f150
Dec 25, 2002 11:43 AM
