Horn installation
Old Jul 17, 2012 | 10:41 PM
Joeseph's Avatar
Joeseph
Horn installation
I am trying to figure out which wire goes were being as the original horn was removed, both of the two coming off of the box next to the horn are yellow so its impossible to tell which is positive and which is negative. I have tried to use my multi meter but I don't see how i'd find the hot lead without pressing the horn button =/
Old Jul 17, 2012 | 11:21 PM
Ford_Six's Avatar
Ford_Six
The horn button provides the ground path to the relay. Basically, you have power coming in to the relay and being split out to both the horn button and the horn. The wire to the horn button first goes through the magnet coil in the relay, and when you press the button completing that circuit, it closes the contact sending power out to the horn.
You should have power on one wire at all times, one with continuity to the horn (or about 4ohms resistance), and the other open until the horn button is pressed.
Old Jul 18, 2012 | 12:06 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
OP has a 1972 F100: 1971/72's have a two spoke steering wheel and a vinyl horn pad. 1967/70's have a 3 spoke steering wheel with either a horn ring (Custom Cab/Ranger) or horn button (Standard Cab).
There is no separate horn wire on trucks of this vintage unless it's a P Series Parcel Delivery. The horn works via the turn signal switch with a horn ring, horn button or vinyl horn pad.
Old Jul 18, 2012 | 12:19 AM
Joeseph's Avatar
Joeseph
The steering wheel was out of a 1960s I installed a grant wheel I am able to get it to respond now when I hit the button but it just makes a clicking sound. I was able to find the constant and it isn't constant it goes up and down and has only hit about 2.9 ohms. Could the box mounted to the radiator support siimply be bad? I hooked it up to the ****** and theres nothing wrong with the horn itself.
Old Jul 18, 2012 | 12:43 AM
NumberDummy
WHOA! The black steering wheel pictured on your truck is not from a 1960's anything. It's from a 1953/55 F100/600!
Since you now have a Grant steering wheel, contact them and see what they recommend how to hook up the horn.
The typical problems associated with aftermarket steering wheels: The horn won't work and sometimes the turn signals won't either.
If it were mine, I'd install the correct 1971/72 steering wheel and vinyl horn pad. Problem solved.
The horns (hi & low) are the same: 1958/82 Passenger Cars/F100/350, 1961/82 Econoline & 1966/82 Bronco.
The horn relay is the same: 1965/66 F100/250 2WD, 1966 F100 4WD, 1967/72 F100/350 // 1965/74 Econoline // 1964 Galaxie/Thunderbird/Falcon/Fairlane // 1965 Mustang w/a generator.
Old Jul 18, 2012 | 02:01 AM
Joeseph's Avatar
Joeseph
My turn signals still work just fine plus I only felt like spending $50 on a replacement steering wheel. The horn works but its hit or miss sometimes the air horn goes off sometimes it just makes a clicking sound. I don't think its getting enough juice that or it isn't grounding out right. The ****** has the horn wired directly to a botton and it blows your ears out everytime you hit it so I know the horn is good. I'm just gonna hot wire the horn and be done with it. The 1960s f250 that first wheel came off has been in the family since new, my grandpa let us put power steering in it in 2009 so I wasn't sure if it was original or not and wasn't surprised when it started turning my hands black and the rubber finally gave out.
On another note I got it to work everytime I scrapped off the paint where the horn button makes contact with the horn.
GlueGuy
2015 - 2020 F150
23
Feb 20, 2017 04:12 PM
InfidelReaper
May 10, 2013 03:36 AM
Ianmattf100
Mar 7, 2013 03:55 PM
sleddog60
May 18, 2009 09:29 PM
SpankF100
Jan 16, 2005 06:49 AM
