Delay Wipers
Old Jul 17, 2012 | 07:28 PM
1972RedNeck's Avatar
1972RedNeck
Delay Wipers
What does it take to put delay wipers in a '75? Does a delay wiper switch plug right in? Is everything else the same?
Old Jul 17, 2012 | 09:19 PM
VocaTexas's Avatar
VocaTexas
You need the controller box that plugs in between the switch and the existing wiring harness, as well as the intermittent switch. Get those two parts and that's all there is to it.
Old Jul 17, 2012 | 09:31 PM
Rogue_Wulff's Avatar
Rogue_Wulff
Pretty much spot on. There is an extra wire coming out of the switch that must be grounded.
The 80-90/91 trucks are a good source for finding the switch/governor. 1 thing to note when using these, the washer plug *may* need reversed, otherwise, totally plug-n-play.
Old Jul 17, 2012 | 10:34 PM
Stinky7-11's Avatar
Stinky7-11
Here you go! If you can't find one local they are all over ebay! I got mine for $20.
73-79 67-72 80-86 Ford Truck Bronco Delay Wiper Switch | eBay
Old Jul 17, 2012 | 10:52 PM
1972RedNeck
So what needs to be reversed?
Old Jul 18, 2012 | 02:55 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by 1972RedNeck
What does it take to put a delay wiper switch out of a newer truck into my '66? I have the two speed switch with the pull for washers.
How many other threads in how many other forums did you type this question besides the 1961/66 forum and this one?
I don't see a 1975 listed in your signature, so I assume you're looking for some sort of confirmation after you received multiple replies in the 1961/66 forum.
What does it take to put delay wipers in a 75? Does a delay (intermittant) wiper switch plug right in? Is everything else the same?
Here is the info...again.
D3TZ-17C476-A (replaced D1ZZ-17C476-A) .. Intermittant Wiper Governor / Marked: D1ZB-17C476-AA or D2ZB-17C476-AA or D3TB-17C476-AA / Obsolete
Applications: 1971/73 Mustang/Cougar / 1973/77 F100/350.
D1OZ-17A553-A .. Wiper Switch-Use with Intermittant Wipers (Motorcraft SW-1010) / Marked: D1OB-17A553-AA / Obsolete
Applications: 1971 Fairlane/Torino / 1973/79 F100/350 / 1978/79 Bronco.
EDIT: ONE governor, over 200 switches available NOS.
Old Jul 18, 2012 | 07:27 AM
1972RedNeck
Nope. I would like to get dad an intermittent wiper setup for his '75 for his birthday. When I found out that you could get intermittent wipers on a '73, I figured it couldn't be to hard to put in a '66.
Old Jul 18, 2012 | 07:32 AM
Raptor119's Avatar
Raptor119
I found an entire set up on EBAY and put it on my 74 F350 SCS. Works well. Plug and play........
Old Jul 18, 2012 | 11:50 AM
Rogue_Wulff
On the 75, there are 2 separate plugs that go on the wiper switch. One has 2 wires, this is the washer pump connection. When using 80+ switch/governor, this washer plug may need to be reversed where it plugs into the governor.
I've been told it does, but the 74 I recently added 80+ switch/governor to has a broken washer bottle, so the washer wasn't functional, therefore I cannot *confirm* this plug has to be reversed.
I can confirm the 80+ intermittant switch/governor will fit and work correctly in 73-79 model trucks though, not including the washer function.
Old Jul 18, 2012 | 12:05 PM
mikeo0o0o0's Avatar
mikeo0o0o0
Here's a picture of the governor box. It plugs into the switch plug on the wiring harness then the intermittent wiper switch plugs into it.
An easy way to see if a truck in the salvage yard has intermittent wipers is to try turning the wiper **** counterclockwise from the "off" position, if it turns it has intermittent wipers, doesn't turn means regular wipers.
The box is located under the dash to the left of the steering column.
Old Jul 18, 2012 | 05:11 PM
conoso's Avatar
conoso
So what year did delay wipers come on our trucks. Our what kind of Ford had this switch in it?
Old Jul 18, 2012 | 05:23 PM
mikeo0o0o0's Avatar
mikeo0o0o0
Post #6 from Numberdummy lists the applications. But they were optional on all years.
Old Jul 18, 2012 | 05:44 PM
conoso's Avatar
conoso
Thanks next time ill look a little closer
captain1997
Dec 17, 2011 05:16 PM
fordyduty
Feb 3, 2010 12:59 PM
madmacs
Jan 8, 2009 01:53 PM
fp_5
Oct 25, 2006 11:45 PM
eazrider
13
Mar 24, 2005 12:50 PM
