Best Block?
Old Jul 10, 2012 | 01:47 PM
1972RedNeck's Avatar
1972RedNeck
Best Block?
I am ready to get a block bored for my 410 build. I have 4 standard blocks.
C6ME-A
C7ME-A
D4TE
391 truck block (can't get to casting numbers)
Which should I use?
Old Jul 10, 2012 | 02:15 PM
Rogue_Wulff's Avatar
Rogue_Wulff
Whichever one will clean up with the smallest overbore.
Alternatively, look around the main webbing. Whichever one looks the beefiest, and cleans up at the smallest overbore.
Old Jul 10, 2012 | 04:13 PM
jowilker's Avatar
jowilker
Agree with Rogue, I would start with the D4TE if I were doing it. That should be a reverse image 105 block.
John
Old Jul 10, 2012 | 07:16 PM
1972RedNeck
All are standard. The 3 FE block webs look similar. The FT still has the pan. Why is the reverse 105 better?
Old Jul 10, 2012 | 07:20 PM
FordmanShane's Avatar
FordmanShane
keep us updated redneck ill be building one of these soon enough.. so have you thought about what parts you're going to use?
Old Jul 10, 2012 | 07:22 PM
FordmanShane
According to Berry Rabotnick the 105's had a reinforced main web design...the benefits are modest at best apparently.
Old Jul 10, 2012 | 08:53 PM
1972RedNeck
I'm going to use the D4TE block bored .030 over, standard 1U crank, C1AE heads, FT exhaust manifolds, Edelbrock Streetnaster intake, 650 CFM manual choke Edelbrock, stock 390 rods, and THESE pistons.
I may use THESE pistons if I can get the cc spec.
I may use THIS cam or I might get a custom ground cam.
Old Jul 11, 2012 | 04:44 AM
RapidRuss's Avatar
RapidRuss
FE "Freakin Expensive"
Yes use the D4 block, as it has the extra main saddle webbing in it..If your going to go to a bigger cam, aluminum intake, bump the CR up some...I didnt look at the piston specs, nor to see if the heads are stock CC's, and if your going to deck the block to get your desired CR along with gasket thickness ? Ditch the stock exhaust logs ! They weigh a ton and are like pissing thru a straw, you wont get much of anything out of your after market breathing parts with stock logs,Some guys like the Edelbrock carbs..to me there a POS..I only run Holleys..But thats just me.. You can pick up a set of Hedman headers for just over a $150, and I have run mine for 40 years now..Also I wouldnt waste the money on a custom ground camshaft with just a warmed over build as your doing..If it was a Preo-street build or track only..I might go that route depending on where I wanted the Tq to come in at ? and how far I wanted to spin the motor with the parts I have, within there grenade range ! JMO..Good luck...
Old Jul 11, 2012 | 07:28 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
Hey Russ, haven't seen you around in a while
Old Jul 11, 2012 | 08:08 AM
1972RedNeck
I will probably just use the Elgin cam. I might call around on custom cams. The FT manifolds are a lot bigger than normal FE manifolds. I don't really like headers.
I will start with a 650 Edelbrock. I have a good assortment of holley's to try out to. I love having spare parts.
1976rustbucket
Apr 25, 2008 11:57 AM
lifted77f250
Oct 27, 2007 09:10 PM
71 Sport Custom
Oct 23, 2005 01:22 PM
77fordguy
General Automotive Discussion
17
Aug 3, 2005 11:04 PM
Adriand
Dec 14, 2004 09:42 PM
