Sponsored by: Real Truck
U joint help!!
Old Jul 8, 2012 | 04:47 PM
brandon.edwards's Avatar
brandon.edwards
U joint help!!
Hey all Ford truckers!
I need some help on the topic of U joints. Im getting that thud noise when i put it in gear and its about due for some drive train maintanence. I have an 04 F350 4x4 and It looks like there are about 1,000 u joints can anyone point me in the direction of a thread or something that can help me in knowing how many i need to replace them all. Also it looks like there are u joints behind my wheels in the front for the 4x4 to work. Are those U joints? and how do i replace those? Any help would be much obliged.....
Old Jul 8, 2012 | 05:13 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
This shows them. Not how to replace them, but shows you all of the U Joints.
Old Jul 8, 2012 | 08:17 PM
redford's Avatar
redford
FTE Leadership Emeritus
Have you greased the slip joint yet?
Old Jul 8, 2012 | 10:40 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
^ What he said. Thats known to cause clunking. Mine is over due.
Old Jul 9, 2012 | 04:20 PM
brandon.edwards
No. I havent done that yet. Where is that located? and also there was nothing to look at as far as the diagram to show all the U joints.
Old Jul 9, 2012 | 09:52 PM
the beast 1's Avatar
the beast 1
u joint help
I would try yhe slip joint first might just need some grease. Mine would clunk a bit when I let up on the brake to accelerate. Greased it up and no more noise. It is located right behind the hanger bearing on the back half of the driveshaft .
Old Jul 10, 2012 | 08:01 AM
DND58's Avatar
DND58
Welcome Brandon. This is what the guys were refering to about slip joint grease. It's easy, and may solve your problem. Good luck.
Slip joint regreasing
JOHNNYACES
Feb 24, 2011 06:29 PM
dynamic
Mar 22, 2009 08:29 PM
Olds_442
Jul 10, 2008 12:46 PM
crashed13
Feb 23, 2006 02:28 AM
