Sponsored by: Real Truck
How to check ATF level?
Old Jul 7, 2012 | 07:35 PM
Saxon's Avatar
Saxon
The dipstick has either hot or cold on it not 'check in park when hot'?
I get inconsistent readings when checking it either 'hot' or 'cold.
Old Jul 7, 2012 | 07:50 PM
dilan73's Avatar
dilan73
I was just doing this the other day and was so confused. my dip stick is all metal with a loop at the end and 2 (O O) above that then the checkered section not like the one in the Haynes manual that has a plastic tip.
here is what i learned .
1) you can, check it either hot or cold
2) when cold, oil has to be between the 2 (O O) markings when hot between the checkered marks.
3) park in a level area.
4) read it when you first pull it because the more you pull the dipstick in and out, the more you go leaving oil through out the dipstick tube, that then obscures a clear reading, at least that's what was happening to me. so make sure to at least read the first one.
hope this helps
Old Jul 7, 2012 | 08:57 PM
Ridenred333's Avatar
Ridenred333
I always drive it for about ten miles or so and make sure that it warms the trans up a bit. Park it on a level surface then place foot on brake run gear shifter thru the gears slowly as to fill diaphram and then put back in park with it running idle and pop hood and pull dip stick.
Old Jul 7, 2012 | 10:06 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
I NEVER check a transmission cold. I don't care what the dipstick says, you can't accurately check the level cold.
Old Jul 7, 2012 | 11:03 PM
biz4two's Avatar
biz4two
Arrow
^^^ ditto ^^^
biz
Old Jul 8, 2012 | 01:35 PM
Saxon's Avatar
Saxon
OK Is that with the engine running or not? when I check it hot.
Old Jul 8, 2012 | 02:20 PM
kd0axs's Avatar
kd0axs
Yes, take it for a good drive so it's up to normal operating temperature, park on a level surface, run the shifter slowly through all the gears, return to park, then check the fluid with the engine running.
Old Jul 8, 2012 | 02:28 PM
BPofMD's Avatar
BPofMD
Veteran: Navy
...and when the fluid is running all up and down the stick, how do you know WHERE the level is??? This vehicle is harder to read tran fluid level than my old Mark VIII!
Old Jul 8, 2012 | 02:29 PM
Ridenred333
Yes leave truck in park and idle.
Old Jul 8, 2012 | 02:34 PM
BPofMD's Avatar
BPofMD
Veteran: Navy
So how long do we leave it idling while the fluid drains down and cleans up on the stick?
Old Jul 8, 2012 | 03:32 PM
dilan73's Avatar
dilan73
id say about 5 min or so that's what i did since i was having trouble really getting a solid indication but i just check it also before i start the engine and also when its hot as others have said.
Old Jul 9, 2012 | 11:01 AM
96DRW's Avatar
96DRW
I was having the same frustration. I believe I'm getting an accurate reading by doing the following:
drive truck about 10 min.
park on level surface.
make sure writing on dipstick is face-up
pull stick, clean, reinsert.
pull stick and read the level on the crossed hatched side which should be facing up.
The side opposite the cross hatched always seems to have oil way up the stick and that can be confusing. I usually reinsert the stick a couple of times just to validate the reading.
Old Jul 9, 2012 | 04:38 PM
BPofMD's Avatar
BPofMD
Veteran: Navy
I will try this....thanks!
meborder
Sep 30, 2014 06:42 AM
1L243
Mar 30, 2011 05:53 PM
waltjmat
Aug 7, 2008 05:44 PM
lbc
2004 - 2008 F150
Jun 29, 2006 05:55 PM
westladog
Jun 12, 2005 07:27 PM
