Sponsored by: Real Truck
E40D dumb question
Old Aug 7, 2008 | 09:29 AM
waltjmat's Avatar
waltjmat
E40D dumb question
Not really sure if I am checking the oil amount properly in my superduty.
It is an E40D transmission. Do I check it with the engine running in park or neutral or do I just leave the engine off and check. I notice on the dipstick there is a hot and cold place for the oil level.
I believe I should check it in park with the engine running, but I want to make sure and I cannot find anything in the manual to indicate the proper procedure.
Thanks in advance for any replies.
Walt
Old Aug 7, 2008 | 09:33 AM
Heavy_Metal's Avatar
Heavy_Metal
engine running on a level surface, P or N, and if the trans is cold when you start it to check it, use the cold mark, if hot, use the hot mark.
Old Aug 7, 2008 | 12:29 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Don't use the cold mark. It's not at all accurate. Always check the trans fluid with the trans warmed up and the engine idling in park or neutral. Park is better, you don't have the chase the truck down the street!
Old Aug 7, 2008 | 01:08 PM
waltjmat's Avatar
waltjmat
Thanks for the quick replies. I thought that was the case, but when I could not find any info in the manual I thought it was safer to ask
Walt
Old Aug 7, 2008 | 05:44 PM
jim henderson's Avatar
jim henderson
A little more to it...
You shoudl shift thru all gears and then go to neutral or park with engine running.
Must be on level ground.
If cold do it as soon as you can get to the dipstick, don't let it sit in the driveway for several minutes.
If warm, don't do it after you have driven around for a long time. I think the manual says to run at normal speeds for no more than ten minutes and then check fluid.
Doesn't hurt to check every once in awhile just to be sure.
Good Luck,
Jim Henderson
neverboredwithaford
Nov 25, 2013 03:42 PM
smitty403
Dec 8, 2010 04:26 AM
C. McAuley
Oct 21, 2010 07:41 PM
LRSTony
Oct 10, 2010 09:17 PM
sharlo
1978 - 1996 Big Bronco
Jun 12, 2000 09:06 AM
