Checking Transmission Fluid Level
Old Mar 29, 2011 | 10:28 PM
1L243's Avatar
1L243
Ok, I admit I am a little confused for something that should be so simple. On a 1999 Super Duty with 7.3 Auto trans you can check it when cold or hot, right? Cold should be anywhere on the "C" cold portion of dipstick? Hot can be anywhere with in the top "H" indicator? OR, should it be when cold at the top of the "C" level and when hot at the top of the "H" indicator?
Old Mar 29, 2011 | 10:49 PM
woodnthings's Avatar
woodnthings
I like mine to be at the top of the scale depending on the temperature. Mine doesn't get "hot" per say, but if the temp is roughly 130-140* I consider that hot or up to normal operating temperature. I would rather be at the top of the scale than at the bottom.
Old Mar 30, 2011 | 03:28 PM
Stewart_H's Avatar
Stewart_H
Just make sure your engine is running!
Stewart
Old Mar 30, 2011 | 05:31 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
In my opinion there is no accurate way to check the ATF when the transmission is cold. Always warm up the trans and check the fluid with the truck parked on a level surface, transmission in park, and the engine idling.
The fluid level should be in the cross hatched area. Anywhere in the cross hatch is fine. It does not need to be right to the top.
Old Mar 30, 2011 | 05:53 PM
big poppa's Avatar
big poppa
Thanks again Mark...
CKetchum
6.4L Power Stroke Diesel
Sep 9, 2016 09:06 PM
muneeb
Apr 20, 2016 03:54 AM
styger
Feb 12, 2016 05:23 PM
TX92F150
Jul 11, 2012 05:31 PM
okst1
Oil & Lubrication
Feb 22, 2006 10:06 AM
