Sponsored by: Real Truck
2005 headlight issue... HID... harness
Old Jul 3, 2012 | 11:33 PM
LSAtexan4x4's Avatar
LSAtexan4x4
i bought my 2005 SD and the previous owner installed an HID kit and now all of a sudden the right one works for about 5 minutes then goes out turn off lights for a while then same thing... any ideas what it could be? i can hear the box buzzing just like the other side... cant find any loose connections...
this is my first run in with HID lights
if nothing else i will go back with stock lamps but he cut off the factory connectors... does anyone know where i can get them or if its a whole harness thing...
thanks a ton
Old Jul 4, 2012 | 01:09 AM
mikeismadness's Avatar
mikeismadness
Sounds like the ballast is failing. Probably getting too hot and killing it.
Old Jul 4, 2012 | 04:04 PM
LSAtexan4x4
and that would be the buzzing box?
Old Jul 4, 2012 | 04:39 PM
woodnthings's Avatar
woodnthings
Yes, your ballast for the HID is bad. You should be able to buy them. Look at Retro-Solutions: Retro-Solutions Store
Old Jul 5, 2012 | 02:34 AM
Yahiko's Avatar
Yahiko
Do this before you buy a new ballast
Swap the lamps right to left and see if the
problem stays or goes with the lamp.
The buzz is the high voltage trying to start the lamp
It takes a high voltage to kick it 10Kv + the lamp
normally runs at about 90 Volts give or take some on both.
If the problem goes with the lamp it's the lamp that is bad
not the ballast. If it stays then it's the ballast.
Sean
Old Jul 5, 2012 | 11:33 AM
LSAtexan4x4
Thanks for the info I'll swap em tonight
Old Jul 7, 2012 | 02:34 AM
Yahiko's Avatar
Yahiko
I got mine from this guy
High Tech Auto Accessory Inc
D2S, H4-2 Motor items in HIGH TECH AUTO ACCESSORY INC store on eBay!
He sells on Ebay. I got the ones I put in my ranger from them
and now the ones I put in my F350. I had a problem with one of the
ballasts and they are sending a new replacement.
The really nice thing is the ballasts they use don't make noise on the AM band.
Unlike some of the cheeper ones
Sean
Old Jul 7, 2012 | 03:36 PM
mikeismadness
I suggest you go the 55w route also. 35w isn't as bright and tends to fail more IMO and experience with HID systems
Old Jul 8, 2012 | 03:02 AM
Yahiko's Avatar
Yahiko
I am running with the 55W 4300K
bi-xeon lamps. Talk about bright!
It's nice driving at night again.
My fog are 35W 300K
Low beam and fog
Sean
12pump
May 22, 2009 02:57 PM
fordracingfan
Mar 6, 2009 07:27 AM
santacruzf250
May 11, 2008 11:57 AM
santacruzf250
May 10, 2008 09:15 PM
empiretc
Dec 6, 2006 08:51 PM
