2002 --> 2005 Headlight Harness schematic?
Old Apr 27, 2008 | 12:31 PM
santacruzf250's Avatar
santacruzf250
Has anyone savvy enough with electrical put together a schematic for the 99-03 --> 2005+ headlight harnesses yet? I'd like to but my own relays and wire it all up. I'm sure someone opted to do this instead of paying $70 to Dfuser. Thanks in advance!
Old Apr 27, 2008 | 06:22 PM
totin_tools's Avatar
totin_tools
Not sure what your asking. When I got the 05 harnesses I just cut the wires off the old plug, and spliced them into the new plugs. Is there some kind of kit your buying or something?
Old Apr 28, 2008 | 12:56 PM
santacruzf250
When you upgrade to 2005+ headlights you need to make/buy a new harness to take advanage of the higher wattage lights. I want to know if someone has MADE this harness as opposed to buying the $69 kit from Dfuser.
Anyone?
Old Apr 28, 2008 | 05:37 PM
leekingen's Avatar
leekingen
santacruzf350--- pm me your address. and i will send you planes and parts list that i have made up
Old May 4, 2008 | 06:35 PM
santacruzf250
Has anyone else wired their 2005+ headlights from home using their own parts? Looking for some schematics
Old May 4, 2008 | 06:42 PM
megawatt00's Avatar
megawatt00
I don't know how much cheaper it would be to make up your own. There are a lot of control panel that I install, look at the inside and say I can do that, till I price out all of the materials and then factor in the labor. ends up being cheaper to buy the panel.
Old May 4, 2008 | 08:14 PM
King0581's Avatar
King0581
I'm interested in that also! Just to see if it would be any cheaper! Help?
Old May 8, 2008 | 09:26 AM
toobad4u's Avatar
toobad4u
I have had the 2005 lights for a couple years now with no problems. I run the silverstar bulbs in them. All I did was cut the original pigtail off, and connect the pigtail for the 2005 bulbs to the wires I cut. Just make sure you get the wires in the correct orientation.
Stephen
Old May 8, 2008 | 03:43 PM
King0581's Avatar
King0581
Stephen what lights are you running, the factory/ford '05's or did you go with something like the eagle eyes? I'm been looking at the eagle eyes and was wondering if they fog up/fade?
Old May 8, 2008 | 08:18 PM
santacruzf250
I ordered a custom HID setup with 9007 connectors and 9008 bulbs for the new 05 headlights. I'll be doing a full writeup.
BTW, HID's are from xenonlink.com, $135.99 shipped!
Old May 10, 2008 | 09:15 PM
toobad4u's Avatar
toobad4u
I bought the lights new from the dealer back in the middle of 05'. I cut the header panel, and mounted them in my 00' model. I recently picked up a late 99' f350, that as wrecked in the front and left side. I swapped them over to it, and put the complete 05' front end on it.
I ran the stock bulbs for a while, and then switched to the Silver Stars. Been good to go ever since.
Stephen
jjennings123
Jul 22, 2014 07:35 PM
Flightpipe
Nov 18, 2010 03:58 PM
enominus
Jun 11, 2007 10:17 PM
Bsienki
Feb 24, 2004 01:32 PM
jason
Electrical Systems/Wiring
Mar 3, 2000 11:17 AM
