1978 - 1996 Big Bronco
Moving Advise?
Old Jul 3, 2012 | 07:14 PM
Edgethis's Avatar
Edgethis
That looks real clean Dylan, just sucks that it doesn't work.
Old Jul 3, 2012 | 07:40 PM
GruesomeJeans's Avatar
GruesomeJeans
Yeah, it's a cheap gauge. I have a tach that will most likely work in there but i have to get my old stock temp gauge working then figure out how to wire this tach up.
Old Jul 3, 2012 | 10:54 PM
Raleigh1's Avatar
Raleigh1
Here is my tach, for now. I plan on making a custom gauge set up.
Old Jul 3, 2012 | 11:01 PM
GruesomeJeans
That looks pretty good. I wouldn't mind doing the same thing. But i'm not sure if my tach is too big or not. I don't know the size of it.
Old Jul 4, 2012 | 11:08 AM
Captbs32's Avatar
Captbs32
AB,
Your always there for me man.
Ya one of these days in a far away land I hope to have A/C one day. I am in the process of getting the factory gauges in an operating condition.
So I have Voltage to both gauges and the water temp one kinda works but it takes a while to go past C.
Oil pressure does not work at all neither does the Alternator one. When I ground them out the oil and water ones they peg out. So seems like that end is fine. So my diagnose was the (cheaper) switches themselves.
Or could it be the ICVR? It doesn't seem that way to me from my research. I think they control the oil,water, and fuel, right? And with the temp somewhat working and the fuel fine it is not that. so might just be the oil pressure switch and might just be whatever thermostat I have in there making it that cool?
Ya I think I have a very sound ENGINE it is just the other smaller components. Wow that sounds like an obvious statement.
What if the tank is not vented correctly, what will be the symptoms?
If that is the case, work removing the fuel cap work for the time being?
damn, alternators. One left us stranded on the going down the mountains of NC on the trail. Our buddy had to drive 2 hours to come get it to us. LOL great times changing one on a Jeep on the trail.
So your pretty much made it 10 miles left on a 300 mile trip. YA good enough.
Mine has yet to make a long trip.
Oh the battery IS perfect. $30 BRand new optima red top. Sometimes you get lucky. The alternator is putting out 13.4 Volts at idle.
Originally Posted by AbandonedBronco
Since you don't have A/C, you don't have the vents on the left and right side of the instrument cluster. Those big, open spaces are great for gauges if you don't mind cutting holes in your dash.
For what its worth, I've put 40,000 miles on my '81 I6 Bronco since I first got it in 2004.
Aside from a vapor lock issue (which just required waiting), it's only left me on the side of the road one time during all those miles when the alternator died. I have to give it credit though, it was on a 300 mile trip through the windy mountains of central Idaho (middle of nowhere) and it died 10 miles from my destination. Close enough for my brother to come get me.
How's your battery? Alternator? Charging system? Is your gas tank venting correctly? (If not, the heat can cause you problems).
Old Jul 4, 2012 | 11:11 AM
Captbs32's Avatar
Captbs32
I have used the SunPro gauges before. Actually have a SunPro tach in my 68 currently. SunPro is owned by Snap-On for what its worth.
Abandoned Bronco has a point, if you don't have factory AC then the dash bezel is a great spot.
Edge,
That is interesting about Snap on owning SunPro. Thanks
Old Jul 4, 2012 | 11:18 AM
Captbs32's Avatar
Captbs32
Originally Posted by GruesomeJeans
As for the gauge in the dash situation this is how my temp gauge is mounted. I hate it. But mainly cause i have 2 of them now and neither work. I want to mount a tach there instead, i just have to figure out why the stock one isn't working.
Here is mine
Little better view with old bezel
It is where the vent is for that side.
Dylan,
Nice streamline set up. Looks good man.
Sucks they don't work. Thanks for the suggestion.
Old Jul 5, 2012 | 10:59 AM
AbandonedBronco's Avatar
AbandonedBronco
Originally Posted by Captbs32
AB,
Heh, I'd love to have A/C one day, but so far, other things continue to take precedence. Oh well, I'm used to not having it and have dealt without for a long time.
Sounds like your gauges work, but they're just not getting a signal. Dunno about the alternator one, but is your oil pressure sender hooked up? It's the metal canister on the rear, driver's side of the engine. (The temperature sender is on the passenger side underneath the rear of the exhaust manifold.) If the wire is unhooked, it's not going to work.
You should have a 195° thermostat in there, not sure how to tell though without a temp gun or something, or just pulling it out and putting in a new one that you know is the right temp.
Yeah, we changed the alternator out on the side of the road. Fortunately, on these, they're really easy to get to! Loosen the belt, take out the adjusting nut, take out the hold down bolt, unplug it, and it's in your hands. Reverse to install. I think we had it up and running in 20 minutes once we had a new alternator.
I will say, though, I'd much rather have it go out a few miles from a parts store than way out on a jeep trail. Granted, it was below freezing out, so that didn't help.
On the fuel venting, the earlier trucks had a ribbed hose that vented the air out of the gas tank. They can get kinked and block the air travel. Then, as the fuel lowers, it creates a stronger and stronger vacuum in the tank. Once it surpasses the strength of the fuel pump, the pump can't get fuel to the engine any more and it dies. This kept happening to me (in the worst places, usually about 30 miles out in the middle of nowhere on old jeep trails) and, no, for some reason taking the gas cap off didn't help. I don't know why.
Eventually, I spent $5 at a junk yard and got an '87+ filler hose, which is a much better design, and a direct swap, and it fixed the issue.
You'd probably know if yours was having the issue, since it'd randomly die and not start again. When I pulled the fuel lines, they were always dry after this happened.
Old Jul 5, 2012 | 11:12 AM
Captbs32's Avatar
Captbs32
Ya it will be a while before I have it.
````LOL ya they are hooked up. I think the water temp one is fine I replaced the oil pressure one. Did a little better connection to the switch itself from the wire and did a better ground from the firewall to the side of the block. That one was real old and brittle insulation.
`````Not sure what thermostat we have in there.
`````NICE
`````It is never fun to work in those cold temps but I prefer it over this HOT weather.
`````Ya I think I am good on that I have not had that issue drove it for about 25+ miles in about 90 degree heat about 55 60 mph so I hope that is good enough test.
Thanks again man.
Old Jul 5, 2012 | 11:18 AM
AbandonedBronco
The problem with the tank thing is it isn't over short distances, it's over LONG ones, like a hundred miles or more. It's when the gas level continually lowers in a relatively short period of time, such as one drive. When it's a short trip and you turn it back off, it has time to depressurize/equalize, that sorta thing.
Not saying you're going to run into the problem, just a heads up since I've had it, and if it happens, you know what it is.
Come to think of it, though, another symptom of it is gas belching back out of the filler neck and onto the ground while you're trying to fill it. If you've had that, it's because the air displaced by the gas can't go out the vent tube and comes out the filler hole instead. If you can fill it normally, it's most likely not an issue.
Old Jul 5, 2012 | 11:24 AM
Captbs32's Avatar
Captbs32
Wow man. Who would think something so easy could cause such a big problem. That completely makes sense might what is happening to my brother 73 F100. I will tell him to check it out.
I replaced the tank last year made sure all the lines were correct but that is not to say something has happened in between there.
OH the day we are moving there is a cold front moving through.
LUCKY ME 85 degrees instead of 95 100. I am getting started real early anyway.
I plan on hooking the oil pressure stuff today when I get a chance.
Old Jul 5, 2012 | 01:52 PM
Edgethis's Avatar
Edgethis
The weather is awlful here. hopefully its decent weather there. Its like a monsoon with the power flickering....
lewis racing
Aug 27, 2014 08:46 AM
Nuthin
Nov 25, 2006 01:16 PM
turborich
Sep 15, 2005 10:41 AM
jgray
Aug 25, 2004 04:12 PM
travisd
Aug 1, 2003 11:37 PM
