caliper key. Got the answer... yay!
Old Jun 30, 2012 | 02:44 PM
Devious Delight's Avatar
Devious Delight
What the Heck. I've been beating on the caliper key for over an hour. I've been soaking it in pb blaster, bolt off, wd-40, and liquid wrench. who has ideas?
I'm tempted to cut the thing out, and buy a new one... If I could find one that is...
Old Jun 30, 2012 | 02:54 PM
fmc400's Avatar
fmc400
MSEE
WD-40 is not a penetrating oil; it's a lubricant.
PB Blaster can take a few days to do its magic if the rust is really bad. Soak it several times a day for a few days. After that, pound at it with a BFH and a brass drift.
Old Jun 30, 2012 | 02:55 PM
mikeo0o0o0's Avatar
mikeo0o0o0
Caliper key should drive out with a punch and hammer. Use a big punch, the bigger the better. Small punches don't transmit the force and shock like big ones. Same with the hammer, use a big one. In this situation, using a small hammer and punchl is the same as just tapping on it.
New ones are available at just about any parts store.
Old Jun 30, 2012 | 02:56 PM
oldford65's Avatar
oldford65
I had the same problem on a 77 f150. I put some burnt oil on it let it sit and just bout still torn the key up getting it out. luckly I had a spare to put it back together with.
Old Jun 30, 2012 | 03:43 PM
Rogue_Wulff's Avatar
Rogue_Wulff
Drive it out from the backside. Trying to drive it from the front, it will hit the steering linkage. I found out the hard way......
I can go either way on my 80, but the steering linkage happens to be in front of the wheel.
Old Jun 30, 2012 | 04:30 PM
Devious Delight
I tried the wd-40 after everything else, I figured it couldn't hurt.
using a big punch and bfh. still no luck.
called autozone and O'reilly. no dice.
I can go either back or front. steering linkage is also in the front on mine.
Any thoughts on heat?
Old Jun 30, 2012 | 05:53 PM
bucks77ford's Avatar
bucks77ford
I spent endless time on mine and then all of the sudden it started to move as I keep pounding with the BFH.
Old Jun 30, 2012 | 06:26 PM
Devious Delight
so when I called O'reilly and Autozone, they said the didn't have it... wrong answer.
found it at Napa
NAPA AUTO PARTS
so I looked at Autozone
Duralast/Brake Disc Hardware Kit - Front (H5545) | 1977 Ford F250 3/4 ton P/U 4WD 8 Cylinders J 7.5L 4BL OHV | AutoZone.com
morons.
took about 2.5 minutes with a cutting disk on the 4" grinder. New ones going in. SO MUCH EASIER (not to mention faster).
Old Jun 30, 2012 | 06:43 PM
bucks77ford
Glad you got it done.
Old Jun 30, 2012 | 09:54 PM
hillbillyk's Avatar
hillbillyk
I have used the hot wrench in the past on some of the nasty ones. not good for the calipers, but they were also getting rebuilt. I did'nt realize you could get new ones.
Old Jul 1, 2012 | 12:13 PM
Devious Delight
this truck has barely been used the last 8 years. new calipers are going in, new pads, new rotors, regreased wheel bearings, pass side is getting a new spindle. Should be nicer when I'm done.
Thedonk
Jun 26, 2016 09:17 PM
heartmyford
Aug 25, 2014 06:20 AM
seventyseven250
Oct 10, 2007 11:03 PM
ERIC79XLT
Sep 9, 2005 03:06 PM
cmoore
Sep 2, 2003 09:38 AM
