Stuck woodruff key
Old Jun 25, 2016 | 07:33 PM
Thedonk's Avatar
Thedonk
Stuck woodruff key
Yeah so i was replacing my harmonic balancer and now the key is stuck and ive tried to chisel it out but no success. I just keep spraying it with wd40 and am hoping to fix tomorrow. Any tricks i should try?
Old Jun 26, 2016 | 08:51 AM
Mudsport96's Avatar
Mudsport96
Try tapping down on one end to try to rock it up on the other end?
Old Jun 26, 2016 | 09:18 AM
megawatt00's Avatar
megawatt00
PB Blaster work much better than WD-40 for removing rusted and oxidized parts. Spray it and let it soak then try what Mudsport96 said
Old Jun 26, 2016 | 10:04 AM
78 PEB's Avatar
78 PEB
AeroKroil works better than PB Blaster. You may try very carefully warming it up with a small torch and while it is warm hit it with a good quality penetrating oil. The heat will wick the oil in as it cools.
Old Jun 26, 2016 | 04:11 PM
'89F2urd's Avatar
'89F2urd
I don't think it's corrosion related.....
Do you have an air chisel?
Need a heavier hammer to go with your chisel. Not the best thing to do, bang on a crankshaft, but you don't have a lot of options.
Old Jun 26, 2016 | 09:15 PM
Thedonk's Avatar
Thedonk
So i did all i could and i kind of just ruined the key lol i too the timing cover off and found that the key is actually pressed underneath the crank gear. So i called my mechanic buddy and he is towing it tomorrow to his shop and is going to remove the gear and get it all done.... There goes about $500 i guess....
Old Jun 26, 2016 | 09:17 PM
Thedonk's Avatar
Thedonk
A tip to anyone who has the inline 6 and is doing a harmonic balancer replacement. If the key isnt bad... Dont replace it!!!!! It will save you alot of money....
Devious Delight
Jul 1, 2012 12:13 PM
Dirty fun
Jan 7, 2010 02:06 PM
Black01Edge
1983 - 2012 Ranger & B-Series
Jan 17, 2008 12:03 AM
prrcatenary
Dec 31, 2007 07:53 PM
cmoore
Sep 2, 2003 09:38 AM
