Sponsored by: Kumho
Front Discs, Key retaining screw issues
Old Oct 8, 2007 | 04:45 PM
seventyseven250's Avatar
seventyseven250
This is on my 1977 F250 Camper Special, with Dual piston calipers.
I was replacing my front Calipers, Rotors/hubs and brake pads, and after sever diffferent attemps, it looks done, except for one problem. I managed to break off the "key retaining screw" on one of the caliper cages. See diagram for details.
Now, my questions are:
1) Can I run without this retaining screw? or will the key slowly work itself out and I'll have a catastrophic loss of the caliper?
2) How can I get the broken part of the retaining screw out?
I have a set of bolt extractors, so I'll look around for them. In the meantime, I would love some advice from the brake gurus here.
Old Oct 9, 2007 | 11:40 AM
Red Monkey's Avatar
Red Monkey
I'm not a brake guru or any other type of guru but here are some suggestions.
I would try a 'left hand' drill bit and some PB Blaster on the broken bolt then try the extractor. But, the PB Blaster will NOT be good for your new pads. Be VERY careful with the extractor as they are hardened and very brittle. If you brake one off you have compounded your problem.
If that fails I'd replace the caliper. The cost of a 'loaded' replacement caliper is a LOT less than the cost of brake failure!!!
Did you try to tap the key out after the bolt broke? I'm not sure if the bolt head holds the key in place or the bolt shank.
I guess you could just drill the hole out and re-thread it using a tap as a last resort.
The EZ route, as well as less time consuming, would be to buy the replacement loaded caliper and be done with it.
Good luck.
Old Oct 9, 2007 | 05:09 PM
seventyseven250
Good luck.
I just put a new caliper on, the place where the bolt threads into is not part of the caliper, I belive it's part of the spindle assembly.
I can remove and re-install the key just fine, the bolt broke in the threaded part and it does not interfere with the key.
I guess as an absoloute last resort, a person could spot weld the key in place against the bracket and leave the caliper floating. that's not my first choice, but it would be safe.
Old Oct 9, 2007 | 06:18 PM
rebocardo's Avatar
rebocardo
You can't spot weld the key, it moves. I imagine you broke the bolt by tightening it, so it will be a hassle to get out. Just use a steady hand and drill out the center (start at 1/16) if you can't get a vise grip on it. Then once you have a shell left, use a pair of needle nose to twist the sides down and pull it out.
Old Oct 9, 2007 | 10:06 PM
seventyseven250
The key doesn't move, it's held in place by the key reatining bolt. The caliper slides on the key.
I think . . . .
Old Oct 10, 2007 | 02:38 PM
rebocardo's Avatar
rebocardo
Take the wheel off the good side, have someone step on the brake, then tell me the key does not move.
I never said the key moved left to right, eh? There is a certain amount of movement when you slam on the brakes, close tolerance does not mean rigid
Old Oct 10, 2007 | 09:38 PM
mark a.'s Avatar
mark a.
I wouldn't weld it. Drill it out and retap it. It doesn't have to be perfect, it just stops it from sliding out.
Old Oct 10, 2007 | 11:03 PM
seventyseven250
I didn't think of that! I was just thinking abut side to side movement, but yeah, I'll beat you are right, that key probably does move back and forth a little with each stop.
I knew welding it wouldn't be a popular choice. Heck, I knew it wasn't the right choice.
I may be spending my saturday on this issue, possibly drilling out the broken bolt, possibly getting a new spindle assembly from the wreckers. I need to pick up a couple things anyway . . . .
Idont want a newF150
Jun 1, 2015 02:29 PM
ROADHOGE250
Nov 1, 2014 05:03 PM
justplumducky
Jun 9, 2014 10:34 AM
f-150 on 22's
1997 - 2003 F150
Jul 26, 2010 11:38 PM
ampegor
May 16, 2004 04:43 PM
