Sponsored by: Auxito
Steering Box play
Old Jun 25, 2012 | 11:31 PM
dvlsmstr's Avatar
dvlsmstr
Steering Box play
Can the steering box in my 2000 F150 2WD be adjusted? When parked and off there is some play left-right.
Old Jun 26, 2012 | 06:16 AM
Lime1GT's Avatar
Lime1GT
Steering boxes are removed and adjusted on a workbench as an inch/lb wrench is needed for checking preloads without steering linkage hooked up. More than likely if the box needs adjustment it's worn out in my opinion.
You sure you don't have worn steering linkage, column shaft or column u-joint?
Have someone turn strg wheel l-r, r-l slightly while you look at strg linkage for side play and up down movement of idler arms and ball ends.
Old Jun 26, 2012 | 05:12 PM
steve(ill)'s Avatar
steve(ill)
yea, look at the linkage, maybe the tie rod anchor/ bushing/ to the frame.
Old Jun 26, 2012 | 06:57 PM
dvlsmstr's Avatar
dvlsmstr
I tightened up the adjuster on top of the steering box. Play all gone. Thanks for replies gents.
istfordinmylife
Jun 23, 2008 11:20 PM
Gottaford
Jun 12, 2008 03:13 PM
carpenter547
May 25, 2008 11:16 AM
djclass22
Apr 22, 2008 06:57 AM
Bookman
Jan 22, 2008 12:03 PM
