69' 250 steering play
Old Jun 22, 2008 | 07:06 PM
istfordinmylife's Avatar
istfordinmylife
Does anyone know what the standard play in the steering should be. I just returned back from Oregon where I got to see my truck for the first time. Put new brake lines on and got it running after sitting for a few years. When I drove it, it seemed to have quite a bit of play in the steering. When looking underneath, I noticed a lot of new orange colored bushings on all of the front end parts. Is ther a way to adjust the steering gear box, or should I be looking elsewhere to reduce the play? My next trip up, I will replace and pack the front wheel bearings before the drive to Phoenix, az.
Old Jun 22, 2008 | 08:15 PM
Ford_Six's Avatar
Ford_Six
You want to check all the tie rod ends, the kingpins, and the rag joint between the steering column and box BEFORE making any kind of adjustment to the box. If you overtighten the box, you can destroy it fairly quickly.
Old Jun 22, 2008 | 08:42 PM
Freightrain's Avatar
Freightrain
Ditto.
Work your way from tires back to the steering box. A loose rag joint will make for sloppy steering, but there may be other issues too.
Old Jun 22, 2008 | 09:19 PM
istfordinmylife
I'll check
Thanks for the replys, I will check from the wheels back to the box. Is the rag joint an easy replace?
Old Jun 23, 2008 | 08:31 AM
Freightrain
The stock one will take a grinder to cut the rivets on the one side of joint. The replacement is a bolt in.
How is your cab mounts? Does the cab sit straight and solid? If it droops in the nose it will eat up any rag joint(old or new) with the constant pressure on it.
Old Jun 23, 2008 | 08:46 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
1969/74 F100/350 2WD steering coupler (rag joint).
2WD or 4WD?
C9UZ3A525A .. 2WD Steering Coupling (rag joint) ~ Fits 1969/74 F100/250 2WD & 1968/74 F350.
Still available from Ford
C9UZ3A525A / MSRP: $75.00 / ftepartsguy.com price: $54.00
If this is 4WD, there is no steering coupling, there is a shaft & coupling assy, along with a U-joint.
Usually it's a defective U-joint that causes play.
If you have 4WD, I need to know the last 6 digits of your trucks VIN in order to list the part number info and availability.
Old Jun 23, 2008 | 10:04 PM
istfordinmylife
Thanks again for the responses! It is a two wheel drive. When I glanced at the box and shaft under the hood it appeared pretty simple looking. It appears to be very open with a lot of room. However I may not want to mess with it myself. I know alot of the basic mechanic stuff and I have alot of common sense, but I may need someone for this one. I took some photos of the truck but don't know how to add it to this tread. The cab appears to sit level.
Old Jun 23, 2008 | 11:20 PM
Freightrain
If the rag joint looks basically straight and solid, then likely it's okay. If the steering shaft and the steering box are NOT in a straight line then it will tear the rag joint.
Have someone sit in the cab and wiggle the steering wheel and watch the joint. If it's all solid then it's okay. If you notice slop where it's riveted thru, then it needs replaced.
Fish_Scientist
24
Jul 20, 2017 10:57 AM
75F150360
Jun 21, 2013 04:09 PM
FDCCHIEF
Jul 9, 2012 08:30 AM
KING
Jun 23, 2011 05:36 PM
X JBM X
33
Aug 28, 2010 08:19 PM
