FICM question please help!
Old Jun 21, 2012 | 06:22 PM
AJB201's Avatar
AJB201
I was told that it is suppose to read 47.5 to 48 but hooked mine up to the scanner tonight and it was reading 45.5 to 46.5. Is this telling me my FICM is junk or that I need new batteries or what? I also checked it when my truck was cold if that makes any difference. The sides were reading 13 to 13.5 . Please let me know what I need to do. Thanks!
Old Jun 21, 2012 | 06:38 PM
mhatlen's Avatar
mhatlen
2006 Bullet-Riddled 6.0
I am guessing your using a scan guage or something of the sort to check ??
The voltage should be as you stated 47-48 volts and around 12+ on supply.
Make sure your batteries are up and in good condition and that your altenator is putting out the amps and voltage that it should. Bad batteries and altenators will wipe out your ficm, I know personally from experience.
Another sign that the ficm is weak is you will start seeing more than normal black soot on the rear bed and bumper. Fix it before you have to replace the injectors, a guy named Ed does a lot of the ficm repairs for a lot of the people on this forum and is highly spoken of.
Old Jun 21, 2012 | 06:41 PM
AJB201's Avatar
AJB201
I have nothing for black soot even with the module up on 65hp setting it doesn't blow black smoke. I am using a snap on scanner. Guess I will check the alternator and batteries.
Old Jun 21, 2012 | 07:29 PM
mhatlen's Avatar
mhatlen
Double check batteries and alt output before you do anything else first.
Old Jun 21, 2012 | 08:22 PM
cheezit's Avatar
cheezit
47.5v is normal. 45v is low but still good per fords tsb
Old Jun 21, 2012 | 08:36 PM
bismic's Avatar
bismic
Personally, I think Ford's TSB was geared more towards trying to minimize warranty claims and they set that voltage limit too low. No real data to prove it, but that is my opinion. I wouldn't want to see anything under 47V, but that is just me - I hate the idea of being stranded.
Old Jun 22, 2012 | 08:53 AM
cheezit's Avatar
cheezit
yup no comment on this staement
Old Jun 22, 2012 | 10:06 PM
blown99's Avatar
blown99
Your FICM is on its way out. I bought a halfshell on ebay and repaired mine in less than 40 mins.
Old Jun 23, 2012 | 12:14 AM
FICMrepair.com's Avatar
FICMrepair.com
Former Vendor
Your FICM is definitely on the way out. Check out my FAQ page at FICMrepair.com for further ways that you can stress test that module, but the upshot is that it needs to be repaired.
We'd of course be happy to help out, providing a better and more reliable end product than what Ford continues to provide 'new'.
Ed
MN_Andy
Mar 28, 2017 06:27 AM
gtadim
36
Mar 9, 2016 09:51 PM
Mazman
1997 - 2003 F150
Nov 30, 2012 04:25 AM
kc2006
Mar 9, 2005 06:16 PM
tr8727
Jan 12, 2003 02:18 AM
