Cab removal question
Old Jun 25, 2012 | 08:39 PM
MNTBUGGY's Avatar
MNTBUGGY
good luck!!!
Old Jul 4, 2013 | 03:07 PM
llacours's Avatar
llacours
61 steering column
I'm pulling and replacing the cab on a 61 f100 4wd. Everyone says "just pull the steering column off. Well I've been trying but it's not moving. The front clip is off and everything is disconnected down to the where it goes into the gear box but I can't get it to move. do I need to pull the entire column apart? I thought I could do this with the steering wheel and column tube still attached. What am I missing? Lou
Old Jul 4, 2013 | 03:15 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Look at pic: Notice that the one piece steering shaft & worm (3524) goes directly into the steering gearbox.
So the gearbox and column have to be removed as a one piece assembly, once Pitman Arm (3590) is removed from sector shaft (3575) or disconnected from draglink (3304).
1961/64 F100/250 4WD same, as is 1965 F100/250 4WD & 1966 F250 4WD / 1961/64 F100/250 2WD similar, also has a one piece steering shaft & worm.
Old Jul 4, 2013 | 07:24 PM
llacours's Avatar
llacours
steering column
Damn! Thanks Bill! Good thing I asked. Everybody I talked to around home said it would just pull out. You just saved me a lot of pain and I'm sure a few bucks repairing the damage I would have done. Lou
Sleepingpoliceman
Aug 23, 2013 07:30 AM
Darrell Maryland
Apr 21, 2013 03:07 PM
56fordguy
Oct 4, 2011 09:53 AM
bill1958
Mar 31, 2005 11:21 PM
Nitro
Jan 16, 2002 05:24 PM
