Tranny fluid change
Old Jun 20, 2012 | 10:21 PM
TAT2DUP81's Avatar
TAT2DUP81
Tranny fluid change
Am wanting to change trans oil and wondering does it matter if oil is SP or the other? LV? Also how many quarts with drain and external filter change?
Old Jun 20, 2012 | 11:06 PM
bismic's Avatar
bismic
8 quarts to drain the pan.
8-9 quarts of you drop the pan.
The external filter holds very little - maybe a few cups.
Old Jun 20, 2012 | 11:16 PM
TAT2DUP81's Avatar
TAT2DUP81
But does it matter which fluid brand?
Old Jun 21, 2012 | 01:14 AM
bismic's Avatar
bismic
Mercon SP or LV.
I have read about folks successfully using Valvoline MaxLife. This product says that it is Mercon SP and LV compatible.
Old Jun 21, 2012 | 08:11 AM
ljutic ss's Avatar
ljutic ss
You can actually mix the 2 fluids.
Old Jun 21, 2012 | 08:22 AM
TAT2DUP81's Avatar
TAT2DUP81
Ok thanks guys. Prob try RP cause we sell at work
Old Jun 21, 2012 | 04:04 PM
cartmanea's Avatar
cartmanea
If you use something other than SP or LV, you should do a full heated flush so you aren't mixing different fluids. Only about half the fluid comes out when you just drain and refill.
Old Jun 21, 2012 | 06:02 PM
69cj's Avatar
69cj
If you still have a warranty stay with the sp or lv. The external filter takes app. 8 oz.
Old Jun 21, 2012 | 09:14 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
If you use a fluid that doesn't have a MERCON SP or LV rating also plan on replacing the transmission. This transmission is VERY sensitive to the right fluid.
Old Jun 21, 2012 | 09:31 PM
TAT2DUP81's Avatar
TAT2DUP81
What's difference in SP and LV???
Old Jun 21, 2012 | 09:32 PM
bismic's Avatar
bismic
Valvoline Maxlife specifically says that it is appropriate for SP systems. Personally I do not like the idea of seal conditioners, but folks are using it.
http://www.valvoline.com/pdf/maxlife_atf.pdf
Even though I know of a person that has used a Royal Purple transmission fluid for 3+ years and has had ZERO issues, I am retracting my statement on it since their web site product brochure says it is NOT recommended for SP / LV systems.
Old Jun 21, 2012 | 09:35 PM
TAT2DUP81's Avatar
TAT2DUP81
Yeah I read that at work. I didn't see anything stating it was safe
Old Jun 21, 2012 | 09:40 PM
bismic's Avatar
bismic
Mercon LV info
LUBE REPORT: Ford Unveils New Transmission Fluid
I don't think that I would go 150k on the fluid. I will probably stick to 30k intervals
Old Jun 21, 2012 | 09:52 PM
TAT2DUP81's Avatar
TAT2DUP81
See dealership had to rebuild tranny when I purchased. It was used FYI. But they should have record of fluid correct ?
Old Jun 22, 2012 | 08:20 AM
69cj's Avatar
69cj
Originally Posted by bismic
Mercon LV info
Owners manual states 30,000 miles.
mattymax
Nov 8, 2014 07:43 PM
Schmitty133
Nov 11, 2010 07:30 AM
gasgrunt88
18
Jun 8, 2009 03:45 PM
tomucen
Aerostar
34
Mar 27, 2006 10:24 AM
jade97
Modular V10 (6.8l)
Apr 22, 2003 12:28 PM
