King pin bush reaming
Old 06-14-2012, 12:50 PM
aussiecowboy's Avatar
aussiecowboy
aussiecowboy is offline
I'll be tackling my king pins in a week or so, I already have the kit but don't have a reamer. I can get access to a set of adjustable reamers but they are not piloted and I'm worried about alignment. Likewise a lot of people have said they use a brake hone tool but that has the same problem. Does anyone know where I can get the correct reamer and what size it is (I'm away from home so can't measure it)? The truck is a 49 F3. Thanks.
Old 06-14-2012, 01:41 PM
ALBUQ F-1's Avatar
ALBUQ F-1
ALBUQ F-1 is offline
They show up on eBay occasionally. I think we ought to buy one and re-sell it around the forum to anyone who needs it, like our own Loan-A-Tool program!
Mine were done by the local NAPA machine shop using a Sunnen hone that was apparently long enough to not need a pilot. They use it for all the truck spindles that come in. You are correct tho, both bushings need to be reamed simultaneously (i.e., piloted somehow).
Old 06-14-2012, 02:30 PM
christurney77's Avatar
christurney77
christurney77 is offline
I know this is old fashioned, but I used a brake hone and just counted how many times I reamed.... Took about 30 minutes per spindle. It can be done this way. (just slow)
Old 06-14-2012, 02:31 PM
christurney77
BTW, I did this last weekend.
Old 06-14-2012, 04:11 PM
fixnair's Avatar
fixnair
fixnair is offline
I took my spindles to an automotive machine shop and they honed them with a wrist pin honing machine. it only took five minutes per spindle and $25.
Old 06-14-2012, 09:31 PM
48ATOY's Avatar
48ATOY
48ATOY is offline
Made my own reamer out of the old pin
Joe
Old 06-15-2012, 04:00 AM
aussiecowboy
That's not a bad idea, how did you get the grooves sharp enough to cut the bushings though?
A machine shop would be ideal but I live in a small town and would have to drive several hours to the nearest shop capable of this work.
Old 06-15-2012, 07:38 PM
48ATOY's Avatar
48ATOY
48ATOY is offline
I used a dremel you only have to cut soft metal
the key thing is the bushing are in line when done
Joe
Old 06-15-2012, 08:05 PM
ALBUQ F-1's Avatar
ALBUQ F-1
You might check with the local Ford dealer, too, the same reamer was used for years.
Old 06-22-2012, 10:47 AM
gsato55's Avatar
gsato55
gsato55 is offline
I rescently found the reamer I needed with pilot on e-bay. Type in kingpin reamer. I hope this helps you.
Glenn
56 F100
Copperas Cove, Tx
Old 06-22-2012, 05:26 PM
HT32BSX115's Avatar
HT32BSX115
HT32BSX115 is offline
I did my F-600 the same way,
Only it was a regular alignment/frame repair facility and they used a Sunnen Honing machine. They obtained the complete 0.010" oversize kingpin kit from Rareparts in Ca.
When it went back together, the steering operated better than new!!
Thisguy65
13
06-09-2017 04:56 PM
sdraymond
02-20-2016 04:35 PM
1959_f100
06-04-2009 01:14 AM
1ole4d
01-14-2007 08:23 PM
mjunk1
12-06-2005 02:24 AM
Quick Reply: King pin bush reaming
