Kingpins
Old May 31, 1999 | 12:49 PM
sdraymond's Avatar
sdraymond
Kingpins
I need some info on installing new kingpins in my 51 F1. Does the spindle have to be taken to a machine shop and the new sleeves fitted to the new pins or can anyone with a good hammer put them in place?
The sleeves feel pretty tight going into the spindle and the pins feel pretty tight going into the sleeves. I don't really want to mess up a new pair of pins guessing.
Any help would be appreciated, thanks.
Steve
Old Jun 2, 1999 | 11:39 PM
Don Chandler
Guest
Posts: n/a
Kingpins
The bushings should be pressed into the spindles, don't hammer them! Then take them to someone with a long reamer of the correct size to match the pins. The reamer needs to be long enough to do both bushings at the same time. Otherwise, they will not necessarily be inline with each other and the pin wll be hard to install. makes for hard turning also. Don't let someone turn the pins down to fit the bushings or the pin will be loose in the axle, Good Luck!
Old Jun 3, 1999 | 11:05 PM
docfestus's Avatar
docfestus
Kingpins
Get a new kingpin/bushing kit.
Find a good automotive machine show and they should know what you need done. They should press the bushings in place and ream them to fit the the new pins ...
just watch/remember were the " washer ", " Soft Spacer " and spacer were when you took the king pin out. The kingpin holds the spindle in place ..
it is a no biggie, you have to remove the tire and the brake assembly, disconnect the tie-rod ends and basically you are done ...
you have to forgive me, it was five years ago since I last did my front front spring and five years before that I re-did the kingpins ...
Old Jun 6, 1999 | 04:45 PM
Steve Raymond
Guest
Posts: n/a
Kingpins
Thanks, I took them to a machine shop and they reamed them for me. They work great, thanks for your help. Steve
Old Jun 7, 1999 | 01:02 PM
Dennis's Avatar
Dennis
Kingpins
Old Feb 18, 2016 | 07:54 PM
bigwin56f100's Avatar
bigwin56f100
Since we seem to have a rash of old posts bumped up I thought I'd bump this one (it was the oldest I could find)
Old Feb 18, 2016 | 10:20 PM
jimcar-9's Avatar
jimcar-9
Hahahahahaa we have the same sence of humor........ Hahahahahaa
Old Feb 19, 2016 | 01:52 AM
Mervy49's Avatar
Mervy49
Hehehe, I just figured it out the other night when some one else on here said these threads are dated so just look up there.
Old Feb 19, 2016 | 05:22 AM
Tedster9's Avatar
Tedster9
Wonder what happened to Dennis's post there.
Old Feb 19, 2016 | 01:08 PM
F250Rob's Avatar
F250Rob
Maybe he partied like it was 1999 and forgot to hit the "post" button.
Did they even have a "post reply" button in 1999? Or did you have to type a bunch of html commands to post a reply?
Old Feb 19, 2016 | 02:45 PM
Tedster9's Avatar
Tedster9
Tin can and string? Telegraph?
"Oh! Tell it again Grandpa, tell it again!!"
Old Feb 20, 2016 | 04:35 PM
CBeav's Avatar
CBeav
Things back then were always more difficult since everything was uphill in both directions
benbuilder
Jan 21, 2018 07:04 AM
Rustypanel
Sep 19, 2017 05:27 PM
zapola6
Jun 20, 2017 09:25 PM
FordStolz68
May 4, 2016 09:08 AM
f100today
Apr 2, 2016 08:09 PM
