interchanging motors
Old Jun 18, 2012 | 08:24 PM
epdp's Avatar
epdp
I have a 51 f-1, will a 289 fit?
Old Jun 18, 2012 | 09:02 PM
52 Merc's Avatar
52 Merc
Yes, with room to spare.
Old Jun 19, 2012 | 12:19 AM
old_dan's Avatar
old_dan
First off....welcome to the forum. Everybody here likes pictures. Also, a little background on your F1 is always a good thing.
Here's a 351w in an F1....very close in size to that 289 you're thinking about:
Old Jun 20, 2012 | 06:45 PM
epdp's Avatar
epdp
Thank you. Answers my question. Once I add the trans etc will the original drive shaft still work or will I need to customize.
Thanks for the help
Old Jun 20, 2012 | 06:46 PM
epdp's Avatar
epdp
it has a flat 6 in it. A 226
Old Jun 20, 2012 | 06:47 PM
epdp's Avatar
epdp
sounds good thank you
Old Jun 20, 2012 | 07:46 PM
old_dan's Avatar
old_dan
If you install a 289 and presumably a modern transmission, you'll need to customize a driveline. I have a C6 behind the 351w....the donor was an F150, so I grabbed the driveshaft & had it cut down by a driveline shop. They added new U joints on both ends...and changed out the rear U joint to match the Ford 9" read end that I'm using. The total bill was around $200.
Dan
Old Jun 21, 2012 | 07:21 PM
epdp's Avatar
epdp
thanks for the info.
Old Jun 21, 2012 | 08:09 PM
AXracer's Avatar
AXracer
Almost any time you swap an engine and/or tranny, a custom driveshaft will be required. You'll probably want a newer rear end as well to get a more useful gear ratio and stronger unit. Go to the top of this page, right below the FTE logo is a menu bar in white. Click on articles and specs and drill down to find the article on rear axle swaps for your truck. You may need to use the rear sump oil pan and pump from a Bronco for additional suspension clearance. Ford still sells them through their performance catalog, and they are fairly easy to find on Ebay.
Old Jun 22, 2012 | 12:12 AM
old_dan's Avatar
old_dan
Since you mentioned a 289, do you already have one or are you thinking of putting something together for your truck?
Old Jun 22, 2012 | 07:05 AM
Moe Craig's Avatar
Moe Craig
Welcome to FTE. Good luck on your truck and as others said we luv our truck pics... Some of us have stuffed Big Blocks in our trucks... I put a Olds 425 Rocket Motor into a '49 back in the early 80's... my current truck has a small block in it...
Old Jun 22, 2012 | 03:34 PM
epdp's Avatar
epdp
I just bought a 289 for 50.00 and started to rebuild it. My truck has its share of, , _ _ _ _ that four letter word. will upload pictures soon.
Old Jun 22, 2012 | 07:15 PM
Moe Craig's Avatar
Moe Craig
LOL... at least you don't have to have your mouth washed out again with soap....
3twinridges
Jan 1, 2017 06:17 PM
4950f1
Mar 21, 2015 10:05 PM
Wayne Waldrep
Sep 21, 2012 09:19 PM
BigPigDaddy
23
Aug 26, 2012 09:20 AM
