Transmission Advise
Old Jun 12, 2012 | 02:16 PM
machmedic's Avatar
machmedic
Transmission Advise
About 3 months/1500 miles ago my tranny started shifting weird and temp jumped from 150 to about 190 degree's quickly all in same drive home. Drove it EASY home about 8 miles and temp never got any hotter. Fluid was in need of changing so I did fluid and filter. Since doing this it has been fine for the most part. Occasionally there is an increased delay going into reverse and I have gotten a 2-3 shift/incorrect gear ratio code (only 3 times in 1500 miles) since fluid/filter change. A couple of days ago right before pulling into my driveway it slipped for a second going uphill in 3RD or OD, I immediately let off of gas. Tranny temp was about 170 degree's. Seems fine now. Question: Should I try Transgo TuggerHD kit and larger cooler, or is it on borrowed time(Which is what I think)? Trying to put off replacement as long as I can. Any help is appreciated. Thanks
Old Jun 12, 2012 | 06:33 PM
F350-6's Avatar
F350-6
I'm not auto transmission guru, but I don't see how a Transgo or any other shift kit will help with your problems. It may mask the symptoms for a bit with the firmer shifts, but it sounds like you've got some worn internals to deal with.
Old Jun 12, 2012 | 07:26 PM
dkrajcovic's Avatar
dkrajcovic
sounds like you need to start saving to get a trans
but then again i am not hte best at trans
Old Jun 12, 2012 | 07:37 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
I don't see a shift kit helping this, either.
Old Jun 12, 2012 | 08:04 PM
machmedic's Avatar
machmedic
This is what I thought. Looks like my truck will become a paperweight for a year or 2 while saving $$. Thanks guys.
outofhours
Aug 27, 2017 09:37 AM
rennat
Feb 4, 2013 07:56 AM
the1mg
Aug 9, 2011 11:24 PM
brian_06328
Jan 21, 2005 11:15 AM
midlf
Nov 3, 2004 09:43 PM
