tranny help!!
Old Aug 9, 2011 | 10:50 PM
the1mg's Avatar
the1mg
Red face tranny help!!
Tranny started acting up just 3 days ago, now it won't go. Started out taking longer than normal to shift from 1st to 2nd. Day 2 started out ok but on the drive home I had to start letting off the accelerator for it to shift from 1st to 2nd. Today, again started out ok but on the way home (hot-hot weather here in H town) the trans temp got up to near 250 deg. and was barely getting the truck rolling from a dead stop. Luckly... I made it to my driveway, drained the fluid, pulled the pan and all I found was about a teaspoon worth of fine metallic sludge.
Any suggestions as to what I should replace other than the obvious fliter & fluid?
Old Aug 9, 2011 | 10:52 PM
BigAlsPSD's Avatar
BigAlsPSD
Did the fluid smell or look burnt? When was the last time it was changed?
Old Aug 9, 2011 | 11:01 PM
the1mg's Avatar
the1mg
No burnt look just metallic swirls and it smelled just like crayons. I'm ashamed to say but it's been about 40k miles since last change. I rarely pull anything other than an occasional car.
Old Aug 9, 2011 | 11:05 PM
Sheldon Plankton's Avatar
Sheldon Plankton
Originally Posted by the1mg
.....all I found was about a teaspoon worth of fine metallic sludge....
Oh, is that all? What were you expecting to find? Sorry, it just sounds funny the way you said it.
Forget about the fluid and filter. Your clutches started slipping three days ago and now your transmission has burned up. Start saving for a rebuild.
Old Aug 9, 2011 | 11:14 PM
the1mg's Avatar
the1mg
Thanks Plankton.... I was afraid that might be it.
On hindsight, as soon as I noticed the slipping was there anything that I could have done at that point to prevent or at least stall the inevitable?
Old Aug 9, 2011 | 11:17 PM
BigAlsPSD's Avatar
BigAlsPSD
I hate to say it but I believe Kent is correct, it is not likely that the new fluid will change a whole lot. Definitely go with a BTS Brians Truck Shop or a John Woods Riffraff Diesel: John Wood Towmaster Trans or John Wood Automotive - Home depending on your location. That is if you intend on keeping the truck...if not cheap rebuild and sell.
Old Aug 9, 2011 | 11:20 PM
the1mg's Avatar
the1mg
Thanks for the leads Big Al !
Old Aug 9, 2011 | 11:24 PM
Sheldon Plankton
......On hindsight, as soon as I noticed the slipping was there anything that I could have done at that point to prevent or at least stall the inevitable?
You could have parked the truck, that's about it. Once they start slipping, death is inevitable and the only fix is a rebuild.
Bonanza35's Avatar
Bonanza35
I don't think so if the fuild was full. I never had a problem till one day waiting for my daughter I backed out of the space and Know forward gears. Kep playing and it want. One week later same thing. Got it home in first and that was it. Put in a JW trans with 6.0L trans cooler and new radiator to run it thur the radiator, mines an e99 didn't have that and all is well. Plus it runs really cool now. I'm in CA and go thur the desert alot towing and driving. So thats a big plus. If you don't want to spend the big dollars then I would go Fords HD trans with 3 year unlimited miles but change the cooler. It would have to be the HD model. Chet
BigAlsPSD's Avatar
BigAlsPSD
I recommend BTS as I'm sure Kent will too, as they just left there, besides I'm just down the road from Brian(Couple hours anyway)
Nichole Campbell
Nov 3, 2017 11:10 AM
SLUF681
Feb 16, 2011 04:35 PM
liftedgrocerygetter
88
Jun 23, 2009 02:20 AM
jfonod
1997 - 2003 F150
Apr 29, 2006 03:39 PM
Bluke
May 2, 2004 08:44 AM
