PCM removal - help needed
Guy's,
1995 F-150 5.0. I have the cable harness removed from PCM, but i cant determine if the PCM is removed by pulling towards engine compartment or from inside cab. The cab location behind the parking brake is very tight.
PCM appears to be sitting inside a bracket.
Thanks!
Thanks!
on
1991 and older trucks the PCM is removed from the inside. 1992 and newer come out the engine side of the firewall.
BuckHammer
26
05-15-2012 04:44 PM
