bilstein shocks for excursion??? which ones to use??
Old Jun 5, 2012 | 11:22 AM
Bluzilla's Avatar
Bluzilla
Question bilstein shocks for excursion??? which ones to use??
Has anyone used the bilstein 5100 shocks on the excursion front and back with the v code and b code swaps? When you did did you order the front shocks as excursion shocks with a 2 inch lift? Or f250 shocks with a 2 " lift? As for the rear which vehicle did you say they were going on and what lift amount? If someone has the part numbers that would be great because I would rather use the 5100 then the 4600 series.
Also can you put these extended 5100 on the truck until the new springs arrive???
Old Jun 5, 2012 | 11:53 AM
X-70STANG-F150's Avatar
X-70STANG-F150
Rear Mounts on F250 and Excursion are different, so you will want the Excursion version. The B Code mod alone will not give you any lift unless you are adding the taller block. I believe the stock size can tolerate a 2" lift.
I think the front mounts are the same. But with the V Mod you are looking at stock F250 vs 2" lift Excursion.
Old Jun 5, 2012 | 03:44 PM
Bluzilla's Avatar
Bluzilla
Question shock numbers
Great info to know concerning the use of excursion shocks in rear cause of the differences. But do you know uf I can put the 5100 on the front until i get the new springs?? Also is there much difference between the 4600 & 5100???
Old Jun 7, 2012 | 07:32 AM
Bluzilla's Avatar
Bluzilla
Question heavy duty vs 5100 bilstein shocks?
Is there much difference between the bilstein 4600 vs the 5100 shocks??
Old Jun 7, 2012 | 09:42 AM
X-70STANG-F150
I had the 4600's but no experience with the 5100's. I liked them alot at first and then wasn't happy with them. I thought they were failing after a year so I bought Monroe Reflex. When I went to change them, I found out my shock mounts had stripped and loosened up and were rolling around the axle. The Bilsteins were fine and I still have them and plan on putting them on my new 04 when I get a chance.
Bottom Line: I couldn't tell the difference between the 4600's and the Monroe Reflex. Both were a huge improvement over worn out stock. I'm not an off-roader so road manners and anything that helps towing is more important to me.
Old Jun 7, 2012 | 09:56 AM
mgraveman's Avatar
mgraveman
I ordered bilstein's heavy duty shocks (blue and yellow) two days ago but if I had to do it again I'd look at Rancho's shock and awe deal with the rancho 9000 shocks. On another thread someone said they got four shocks and a lift kit for $18 after rebate.
mgraveman's Avatar
mgraveman
https://www.ford-trucks.com/forums/1...-a-budget.html
colleensmith915
May 7, 2017 05:53 PM
Mississippi013
Feb 11, 2016 09:22 PM
kcdude
Sep 4, 2011 01:03 AM
toolboxjunky
Oct 10, 2007 10:50 PM
checkered02v10
Jul 2, 2007 06:40 PM
