Sponsored by: Auxito
electrical problem?
Old Jun 1, 2012 | 09:33 PM
jasonhamilton1978's Avatar
jasonhamilton1978
Cool electrical problem?
today all of the sudden my ford f150 5.4 liters speedometer started to not work and the airbag light came on while it was having trouble shifting! the windshield wipers don't work as well! checked all fuses! after messing around with smacking things under the hood it started to shift right but has a glitch in the electrical and it sounds like it's trying to start( this is while it's running) it's all glitchy and i would like to know if anyone has had similar issues?
Old Jun 1, 2012 | 09:36 PM
jasonhamilton1978
would love to know before i have to take it in and have ford devour my bank account
Old Jun 28, 2012 | 08:46 PM
maverick1701's Avatar
maverick1701
was it by chance raining that day? or did you go through a car wash right before it happened?
It's common for water to leak down on some mucho importante electronics and cause issues
Old Jun 29, 2012 | 12:32 AM
ford2go's Avatar
ford2go
It sounds as if you may have some issues with ground connections. Folks have reported strange issues if the ground strap in the engine compartment is bad. But, it could be any ground.
Alldata ( an online reference) sometimes shows drawings of the ground locations. Around here you can get access to Alldata at the library. Might be worth checking out.
Failing that, you can get a voltmeter and try and find grounds. Try checking for voltage between various grounds and your battery negative terminal. (You can CAREFULLY use one lead of a jumper cable on the battery to the meter lead). You should activate things like lights/heaters etc while you're doing this. If you see anything more than a tenth of a volt or so it's worth checking.
Ranger guys are always talking about a GEM module ( General Electronics Module) that can fail and screw up a lot of things. I don't know if there's an equivalent on the F150.
Good Luck,
hj
Old Jun 29, 2012 | 11:12 AM
canacka's Avatar
canacka
Check out this thread, it may help.
https://www.ford-trucks.com/forums/1...1997-f150.html
KF4EYR
1983 - 2012 Ranger & B-Series
Feb 3, 2016 01:54 AM
Rich1953ard
Apr 17, 2013 11:10 AM
qepv25a
Mar 1, 2012 10:37 AM
mikecox1
Aug 21, 2009 05:08 PM
biederboat
Aerostar
Nov 17, 2004 04:11 PM
