Please Help Me Diagnose - Electrical Problem
Old Aug 19, 2009 | 09:02 AM
mikecox1's Avatar
mikecox1
My Exp is a 2000 EB, 5.4, 2X4, 196,000 miles.
My truck has an elictrical problem. This morning when I tried to start it, it acted like it had a dead battery, but it didn't. Here's how it went.
1) Disarmed the alarm with the fob - acted fine, no sign of a weak battery.
2) Opened the door - acted fine, interior lights and running board lights were bright
3) Tried to start it - all hell broke loose
  • All lights went out completely
  • The alarm went off sounding like it was drunk (very low volumn and slurred)
  • The ignition just clicked
For all intent and purposes it acted like the battery was bad.
I opened the hood and the hood light was even out completely. I disconnected the battery and reconnected it again. In doing that full power came back to everything instantly. It was as if disconnecting the battery had reset something in the electrical system. So I tried to start it again, and all the previously mentioned bad stuff happens again.
I go through this process four or five times and it finally starts like there was never a problem. I drove it to work and had no driveability issues. After getting to work I turned it off and started it again just to see if it was going to start and it did. The whole thing was just odd.
Does anyone have any experience with anything like this. Cars don't fix thenselves and the last thing I want to have happen is for this to leave my wife and children stranded if I'm not there.
Any ideas would be greatly appreciated.
Old Aug 19, 2009 | 02:05 PM
minitrk's Avatar
minitrk
Sounds like there might be a bad or corroded connection somewhere.
Old Aug 19, 2009 | 03:54 PM
TexFinn's Avatar
TexFinn
Yup. Most likely just a bad connection at the battery terminals. Take both cables off, clean everything with wire brush and then reconnect and make sure the connection is tight.
Should make the problem disappear.
Old Aug 19, 2009 | 06:11 PM
projectSHO89's Avatar
projectSHO89
Piling on.
Bad battery connection or cable.
If cleaning the connections doesn't work, the cable has probably rotted from the inside.
Old Aug 21, 2009 | 02:04 PM
briank's Avatar
briank
Sounds like you battery may below the require volts. Had the same thing happen on my 2004 Expy. Replaced the old battery and all is fine.
Old Aug 21, 2009 | 05:08 PM
rpatrick's Avatar
rpatrick
Ditto for me, too.
A couple of winters ago I had the same symptoms you described. Lights and everything else seemed to work but no start. Replaced the battery and the problem went away.
Check the cables to make sure nothing has come loose. Invest in a battery terminal brush and clean the terminals/connectors. If it still acts wacky, I'd bet on the battery.
69 F100 Cali
1983 - 2012 Ranger & B-Series
16
Oct 9, 2013 07:41 PM
Ogre39
32
May 31, 2013 06:53 AM
Plain Jane
Jul 8, 2011 12:47 PM
moto
Escape & Escape Hybrid
Mar 27, 2006 02:07 AM
jtmt72
Dec 8, 2005 09:50 AM
