My "let's fix this truck" thread
Old May 29, 2012 | 08:15 PM
Regulator1988's Avatar
Regulator1988
Ordered all the parts. Check
Started tearing down. Check
4 hours in ran into first problem. Check
This is where I sit now.
On the driver side there is a turbo bolt. I rounded it off
Old May 29, 2012 | 08:24 PM
Piolet's Avatar
Piolet
Gotta replace that oil filter cap. It's the wrong one.
Do a search on here for the problems it causes.
https://www.ford-trucks.com/forums/1...-look-for.html
https://www.ford-trucks.com/forums/1...l#post11527650
Old May 29, 2012 | 08:26 PM
texastech_diesel's Avatar
texastech_diesel
Token Redneck
Two weeks..... good luck man, we'll be cheering you on
Hammer on a socket and use a wobble?
Old May 29, 2012 | 08:39 PM
BLADE35's Avatar
BLADE35
EXCELENT CATCH COLM Give this MAN some REPS somebody Im all repd out thanks
Throw a IPR and oil filter cap on the List odds are its Toast and might be your Problem
since Boost is generated From Exhaust EVERYTHING Before it Must work PROPERLY
Old May 29, 2012 | 08:49 PM
BLADE35's Avatar
BLADE35
6point wrench ONLY on them turbo Bolts
I assume you Mean the turbo Bolts rounded off
Sears sells a Fu!! Bolt remover
Try Bryans Method First
If it dont work go to sears and get the Bolt remover DONT get the one for the same size as the Bolt Head with the bolt being Flared Odds are it will Bottom out on the Flange before it breaks it Loose
But get the size thats Like 16mm17mm18mm19mm oone of those cant remember exact size But You need the one that will Go over the BoltHead AND Sleave or the round spacer
Iv been down this road them bolts are cooked in there and installed DRY it can be a MotherF@!%!#@
I antiseize just about everything going backtogether
the turbo going to be a PIA but once you get past it Not to Bad
Old May 29, 2012 | 08:57 PM
Rusty Axlerod's Avatar
Rusty Axlerod
Soak the bolt in spray lube. Use a 6 point socket. Use the right combo of extensions to get on it straight. Sounds wrong but since the corners of the bolt are rounded already try to tighten it VERY slightly before turning it in the loosen direction. Those corners of the bolt aren't rounded yet. I just pulled mine over the weekend and used a socket and extensions, I forget the combination of extensions I used but the head of the ratchet was just inside the edge of the rocker box (valve cover). Bolt was 10mm. Good luck!
Old May 29, 2012 | 09:02 PM
Piolet's Avatar
Piolet
I remember cheezit posting about a fancy tool he had that was a coil that could fit over the bolt head or nut. Electromagnetic induction heating then did the rest. The part was heated to cherry red without the use of a flame and then it could be loosened.
I'll have to wait for the Harbor Freight version though
Old May 29, 2012 | 09:18 PM
Regulator1988
Ya only 6 point here guys
Old May 29, 2012 | 09:20 PM
Regulator1988
DAMN DAMN DAMN your good.
What's the part number of the cap I need?... Anyone
Old May 29, 2012 | 09:21 PM
Regulator1988
I know....
Old May 29, 2012 | 09:25 PM
BLADE35's Avatar
BLADE35
Originally Posted by Regulator1988
I know....
Hey you got LUCKY its a Front Bolt thats JACKED UP
Mine was the REAR Bolt that ended up Jacked up
I dont think Iv EVER had a Bolt KICK MY *** like that rear turbo bolt did
Old May 29, 2012 | 09:26 PM
Regulator1988
How do you get to it?
Piolet's Avatar
Piolet
Got you covered there too
[EC781]Motorcraft oil filter cap for Ford 6.0 liter diesel pick up truck oil filter(EC-781-3C3Z-6766-CA) - Diesel Filters,Additives,brake rotors, and brake pads for Chevy, Dodge and Ford Diesel Trucks
Old May 29, 2012 | 09:28 PM
Regulator1988
Rep when I get home
Old May 29, 2012 | 09:31 PM
Piolet's Avatar
Piolet
Thanks!
Just helping out when I can in between commercial breaks watching "Hatfields & McCoys".
