My "let's fix this truck" thread
Old Jun 7, 2012 | 09:02 PM
  #121
Regulator1988's Avatar
Regulator1988
Originally Posted by SteveBricks
It would be a good idea to change that EGR to Oil cooler hose to the updated Blue one while you're in that far. The Orange ones are prone to leak.
How do I get the hose off?
And do you know the part number of that hose?
Old Jun 7, 2012 | 09:35 PM
  #122
BLADE35's Avatar
BLADE35
https://www.ford-trucks.com/forums/1...l#post10609697
I had that Fancy blue hose come with my Intake Gaskets
But I ended up using the Peice of blue hose that came with egr deleate and 2 worm drive hose clamps
I figure the higher odds with Oring Fail in the OEM Part so that why I went old fashion hose clamp combo
You can just get a peice of 5/8heater hose though
Old Jun 8, 2012 | 12:22 PM
  #123
Regulator1988
5/8 heater hose and clamps?
Old Jun 8, 2012 | 04:14 PM
  #124
sergbaja5t's Avatar
sergbaja5t
Hey Blade, did you have any smoke/coolant burning issues before the tear down or did you this out preventive maint?
Old Jun 8, 2012 | 05:22 PM
  #125
Regulator1988
Did you mean to direct that to me?
Old Jun 8, 2012 | 08:22 PM
  #126
BLADE35's Avatar
BLADE35
Yes Sir
I just measured it the OEM one I didnt use
it Measures 11/16 Inside Diameter on the OEM One with the Orings its probably 5/8 at the Orings inside
Now I used 5/8 ID heater hose for my coolant filter
You will be fine with 5/8 inch ID heater hose and couple clamps
Or they had that little Hose with a Intake manafold gasket kit which ever you want to go
Hows the project coming anyways are you making any headway
Old Jun 8, 2012 | 10:38 PM
  #127
sergbaja5t's Avatar
sergbaja5t
Sorry bout that Reg, I had multiple windows open .
Old Jun 8, 2012 | 10:42 PM
  #128
Regulator1988
It's cool.
And if it was. Yes but not much. Just at start up
Old Jun 9, 2012 | 06:14 PM
  #129
Regulator1988
Truth telling time!!
I actually had 3 weeks from the beginning. One week left till I have to move
Old Jun 9, 2012 | 09:29 PM
  #130
Regulator1988
Adrian came through
  #131
Regulator1988
FICM is here also.
Old Jun 10, 2012 | 05:34 PM
  #132
Regulator1988
9 of the passenger studs done. One left
Old Jun 10, 2012 | 08:48 PM
  #133
Regulator1988
All studs are done. Next 2 days to put it together
Old Jun 10, 2012 | 10:53 PM
  #134
sergbaja5t's Avatar
sergbaja5t
Really how much of pits was the studs to do,Reg?
Old Jun 10, 2012 | 11:25 PM
  #135
Regulator1988
Actually... Not too bad.... Passenger side cake walk driver side ok just that one bolt on the very back on the bottom but if you undo the engine mounts and the trans crossmember jack up on the trans to tilt the engine then it comes out. So overall 7 out of 10
