Regulator1988,
I would like to help but don't have an extension that can reach from Tacoma, Washington to Waco,Texas.
If you were closer by I would be more than happy to give a hand.
Have you gotten the stuck bolt off? This will work for any stuck bolts
Did you try the Kroil on it? That stuff does work very well it just needs a bit of time.
Try to get it into the threads. Spray it on any thing you think is going to be stuck .
Regulator1988,
Sean
Is there one that you could buy
And I did get that bolt the only one left is the PITA one in the back
I have not had the truck long enough to have to pull the turbo yet.
You should be able to pick up the Kroil local.
That extra long extension I think is still in planning at NASA
so they can fix the space station with out any Space Shuttles.
EEK got to run to the dealership They have to fix some thing that they
fixed and did not stay fixed.
