bell housing patterns
Old May 5, 2003 | 07:01 PM
rustydog628's Avatar
rustydog628
What ford engines share the same bell housings / flywheel patterns with the 300 l6?
Old May 5, 2003 | 08:26 PM
knocturnal's Avatar
knocturnal
302 and one or two of the 351s
Old May 5, 2003 | 08:58 PM
ecarter50's Avatar
ecarter50
300, 302, 351c, 351w all have the same bellhousing bolt pattern. Flywheel bolt patterns are the same for those engines also but the 300 is balanced while 302, 351c, 351w has 28oz or 50oz imbalance.
Old May 5, 2003 | 10:45 PM
optikal illushun's Avatar
optikal illushun
u sure about 351C cuz i thought there were a different series of engines?
Old May 5, 2003 | 11:37 PM
steve83's Avatar
steve83
Me too. I don't think the 351c belongs in that group.
Old May 5, 2003 | 11:55 PM
Ford_Six's Avatar
Ford_Six
Oh boy, the 351 debate again. The 351c uses the small block pattern. The 351m uses a big block pattern. The windsor is an overgrown 302, the 240-6, the 3.8 v6 (in trucks), as well as the 255-8 used the same pattern. So, pretty much anything that is not a big block, small six, or that has an "M" after the cid size can be used.
Old May 6, 2003 | 12:00 AM
rustydog628
Does this mean this 351M can be brought to 400 Cu" ?
Old May 6, 2003 | 10:09 AM
optikal illushun
thanx for clearin it up! never knew they used the same bell housing for so many engines...maybe i can swap a built 351C behind my e4od and adapt 351W EFI to it...j/p
Old May 6, 2003 | 11:34 AM
Ford_Six's Avatar
Ford_Six
The 352m can be stroked out to a 400 by replacing the crank and pistons. The rods are the same. I forgot to mention, though, that no other flywheel will fit the 300-6, aside from a few exceptions: a racing flywheel or flexplate, for a 302, that says it is for an internally balanced engine will work. Also, the 289 shares the same bolt pattern for the bell.
Old May 6, 2003 | 05:08 PM
82F100SWB's Avatar
82F100SWB
But, if you can't find a 300 specific flywheel, just have one of the other flywheels that fit brought to a neutral imbalance at the machine shop when you have it turned.
Evan
Old May 7, 2003 | 09:27 PM
steve83's Avatar
steve83
This page is pretty thorough on Ford engine blocks.
raven3
Jan 28, 2014 10:48 AM
swooshcmk
May 15, 2010 02:03 AM
littleme13
21
Mar 18, 2008 10:58 PM
straightsix4x4
Jan 29, 2008 10:45 AM
Alwaysfixin
May 31, 2007 10:03 AM
