Gas guage problems??
Old May 29, 2012 | 01:35 PM
77f-250's Avatar
77f-250
when i ground out the gas gauge with a test light the light pulses dimly and will only go up to 3/4 of a tank is it the gauge or am i just robbing that little bit of power needed to peak out the gauge by running the light?
Old May 29, 2012 | 09:11 PM
fmc400's Avatar
fmc400
MSEE
That's normal, and expected. What is the actual problem? Or are you just curious why it does that?
Old May 30, 2012 | 04:33 PM
ford_dude_55's Avatar
ford_dude_55
the fact that it only goes up 3/4ths of the way is concerning would it be because the test light is robbing the power?
Old May 30, 2012 | 07:31 PM
fmc400's Avatar
fmc400
MSEE
It only goes up 3/4 of the way with a test light in the circuit because the impedance of the test light limits the current through the gauge, which limits the swing. Like I said, everything he says sounds normal. But there's not much value in doing what he's doing.
The correct way to test the gauge is to put it all back together, then ground out the lead going back to the sending unit, out at the sending unit itself. If the gauge doesn't peg FULL, make sure there is a good ground out there (sometimes you have to run a jumper wire to sheetmetal under the bed). 99.99% of fuel gauge problems are out at the sending unit area, whether it's a bad sending unit, float, or bad ground at the frame.
If you're trying to truly calibrate the gauge, you should use 10 and 70 ohm resistors. That's another story.
I still don't know what the actual problem is, so I'm not really sure how useful I can be here.
wc870
Jun 3, 2016 09:08 AM
BossFan
Nov 21, 2011 10:32 PM
BossFan
Electrical Systems/Wiring
Nov 13, 2011 04:27 PM
74hiboy
Oct 20, 2005 07:19 PM
jetta4
Apr 1, 2005 06:59 AM
