gas gauge problem
Old Nov 13, 2011 | 12:07 PM
BossFan's Avatar
BossFan
gas gauge problem
So LMC sent me my new 38-gal tank and all went fine with install except I still have no reading on my gas gauge. The gauge worked when the sending unit was in the old tank and also worked after my buddy soldered on the extended pickup. To make sure it was getting power, I put a test light into the connector where the sending unit pigtail connects to and my test light was blinking. Not a full constant light. I then disconnected the big wiring clip under the hood and sure enough, when I tested two of the pins, they were blinking as well. The attached photos show where I am getting the blinking test light readings.
Is this normal? If yes, then I have to guess the problem is with my sending unit, but if it is not normal and I should have a constant 12V going back to the fuel tank, and it is blinking where it comes out of the dash harness, and suggestions on my next step?
Thanks
Frank
Old Nov 13, 2011 | 01:28 PM
fmc400's Avatar
fmc400
MSEE
The blinking is an effect of the ICVR (instrument cluster voltage regulator) and is normal. The signal to the sending unit is not a constant 12 volts, it's downstream of a gauge that's powered by a pulsed 5-volt supply (the ICVR).
Check that the fuel gauge pegs to FULL by removing the signal going to the fuel gauge and grounding it. If that does not work, then check the ground at the sending unit.
I am not able to verify your probing locations shown in your pictures, but I think it's a moot point since this is not the place I would be looking. If everything worked with the old tank, you need to focus on the wiring near the tank (which is where the gauge feed from the dash connects to the sending unit, and where the sending unit grounds). These are the only things that could have changed.
Old Nov 14, 2011 | 12:23 PM
BossFan's Avatar
BossFan
Thanks for the reply. To ground out the power wire near the tank (where I used the test light to see the blinking), all I have to do is run a wire into the female connector (it was a pull-apart connector) and then ground that to the frame? At that point, since the power wire is disconnected, it really doesn’t matter about the ground on the sending unit, right?
Old Nov 14, 2011 | 02:11 PM
400 .040over's Avatar
400 .040over
teh sending unit is on the ground side,by grounding the wire to the gauge should peg the gauge full.
Old Nov 19, 2011 | 03:10 PM
BossFan's Avatar
BossFan
I bought a new sending unit and a new wire harness for the unit. I have the pulsed power back to the connector, but as soon as I connect the sending unit wire (blue in picture) it grounds out the power wire (green) and pegs the gauge. If I disconnect the sending unit ground from the frame, then power will flow through from green to blue, but I get no gauge reading.
I don't understand why the sending unit would be grounding out the power wire. There are only two wires here. A power wire and a ground. THis shouldn't be this hard.
Old Nov 19, 2011 | 03:56 PM
OldStyle's Avatar
OldStyle
Rusty Roller
Hi
You keep saying "power". The sender sends a "ground" signal to the gauge. When the wire back there at the sender is put to ground it acts as if the sender is sending a "full" signal up to the gauge. When the tank is empty the sender sends a "open ground", so to speak, signal to the gauge; and the gauge reads empty.
Ground the wire back there, from the gauge, and see if the gauge reads full. Report back.
Old Nov 19, 2011 | 04:34 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
Keep in mind with a 38 gallon tank, it will read FULL until you have used half the tank of fuel or have around 19 gallons. Then the gauge will start reading normally.
Also, there is no "power" wire at the sender. It is a ground "SIGNAL" wire. The sending unit is a resistance to ground, therefore, at full tank you have full ground, 1/2 tank half ground etc.
Josh
Old Nov 21, 2011 | 06:22 PM
BossFan's Avatar
BossFan
THanks for the replies. If I understand you all correctly, when I have the sending unit attached to the wire that runs up to the gauge, and I use a test light to pierce that wire, I should see no 'light' because it is not sending power, rather, it is grounding it out. If that is correct, then I think everything is working correctly. I have about 3/4 tank of gas in truck and the gauge is pegged past full, but that's because it won't really start giving a 'reading' until I get down below 19-gallons.
Frank
Old Nov 21, 2011 | 06:40 PM
OldStyle's Avatar
OldStyle
Rusty Roller
Not being familiar with larger tanks but that sounds correct especially if when you remove the wire from the sender the gauge drops to empty.
Old Nov 21, 2011 | 07:28 PM
Stinky7-11's Avatar
Stinky7-11
Thanks
Frank
Sounds like you got it figured out. I would be interested in the same tank, how would you rate the quality of this tank from Lmc?
Thanks
Old Nov 21, 2011 | 07:36 PM
JB78f150's Avatar
JB78f150
I'm on my second send back from LMC and still can't get a tank that isn't destroyed by the time in gets to my front porch. They put no protection in the box so all the seams are bent and split. I haven't been able to install it yet but I hope its good.
Old Nov 21, 2011 | 10:32 PM
BossFan's Avatar
BossFan
This is my second tank. The first one lasted two fill-ups before it cracked after something kicked up from the road. LMC did warranty it and when they shipped the second tank, they double-boxed it and had foam all around the inner box. That's probably how they should always ship it, but it had to come UPS Freight the second time.
Jon003
Mar 24, 2022 04:02 AM
78fordguy
May 27, 2015 03:05 PM
BossFan
Electrical Systems/Wiring
Nov 13, 2011 04:27 PM
77f250400
Jan 8, 2011 11:19 AM
evanderson
1978 - 1996 Big Bronco
May 6, 2003 12:09 PM
