how to test....
Old Jun 3, 2016 | 04:17 AM
wc870's Avatar
wc870
how to test....
good morning, need a little testing help, my fuel gauge doesn't work on my 65 c/s cutom cab. how should I go about testing to see if its the gauge or sending unit? thanks in advance
Old Jun 3, 2016 | 05:03 AM
jowilker's Avatar
jowilker
I installed a new one a few months ago and found grounding issues there at the gas tank where the wire plugs in. Did some scraping and the gauge worked much better.
John
Old Jun 3, 2016 | 08:31 AM
jhorst14's Avatar
jhorst14
should be able to connect a voltmeter or even a test light to be able to trouble shoot if you getting a signal from sending unit to gauge. I am not expert by any means but normally get out my test light and start checking things. like jowilker says, try checking/cleaning grounds first, that is usually the issue with these older trucks.
Old Jun 3, 2016 | 09:08 AM
hiball3985's Avatar
hiball3985
Simple test, remove the wire from the sending unit and ground it, the fuel gauge should go to Full with the key on. Another issue could be the float on the sending unit, if it has a leak and fills with gas it will be at the bottom of the tank giving you no reading ( empty ) on the gauge.
SideWinder4.9l
Electrical Systems/Wiring
Jan 30, 2022 07:53 PM
77f-250
May 30, 2012 07:31 PM
RubenRuben
May 1, 2012 09:52 AM
BossFan
Nov 21, 2011 10:32 PM
BossFan
Nov 13, 2011 04:27 PM
