Best Injectors
Old May 27, 2012 | 07:11 PM
Regulator1988's Avatar
Regulator1988
Best Injectors
What are the best replacement injectors and if i plan of staying stockish should i bump up one size and if i do will i loose gas milage
Old May 27, 2012 | 07:13 PM
bismic's Avatar
bismic
OEM remanned injectors or FullForceDiesel. Those are the only two choices IMO.
Old May 27, 2012 | 07:17 PM
Regulator1988
bismic your in dfw yes?
Old May 27, 2012 | 07:22 PM
bismic's Avatar
bismic
no - way down South of you
Old May 27, 2012 | 07:31 PM
Regulator1988
lol damn, who is in the dfw area?
Old May 27, 2012 | 08:09 PM
BLADE35's Avatar
BLADE35
I think Cheezit is but I could be Totaly wrong to If it was me Id send him a PM with your issues He will get you fixed up for shure
I hope your Planing to do ARP studs and you will also need a Tuner to Balance out the Air/Fuel Ratio with the Bigger injectors
Iv heard they can turn up OEM injectors pretty good to IDK
Old May 27, 2012 | 08:11 PM
Regulator1988
like i said i have about 2,000 and I need this problem fixed, idk if im going bigger injectors I just need this truck not to brake down ever
Old May 27, 2012 | 08:18 PM
BLADE35's Avatar
BLADE35
Well with Bigger injectors and a tuner Im thinking that alone would be around 2K and thats with You doing the Install that dont include ARP studs either and the stuff that goes with it
and thats not figuring what you need to make it run right with your other thread and problems
Old May 27, 2012 | 08:22 PM
Regulator1988
Well with Bigger injectors and a tuner Im thinking that alone would be around 2K and thats with You doing the Install and thats not figuring what you need to make it run right with your other thread and problems
damn how much are injectors
I saw the powermax turbo for 1,000
Arp Head Studs, About 450
EGR and Oil cooler kit 800
so thats 2500...
Old May 27, 2012 | 08:33 PM
BLADE35's Avatar
BLADE35
IDK for shure on bigger injectors
But OEM Injectors go for 220.00 a peice so thats 1760.00 for 8 inject
If it was me Id ARP it and tune it just turn up the OEM injectors for now you might be surprised with the preformance
and then do bigger inject when Funds are advalible IDK
Old May 27, 2012 | 08:36 PM
SuperVossen's Avatar
SuperVossen
From my knowledge your not going to be pushing enough fuel for a bigger turbo, count that out for now..
Performance* Injectors are around $400 each avg. including cores.. some are more expensive, some a little less. depending on what you want. What are your goals?
ARP's- a must in my opinoin. I am doing a cab off as we speak.
EGR- be careful on a delete. rear y-pipe i have heard has a tendency to crack w/o the support of the EGR cooler
I would check out BulletProof Diesel i have heard nothing but good about their coolers.
Old May 27, 2012 | 08:43 PM
texastech_diesel's Avatar
texastech_diesel
Token Redneck
so thats 2500...
Plus the actual headgaskets and $300 to deck the heads. Maybe the standpipes. I'd put the sticks and Powermax on hold until the studs and coolers are done. You can get a lot out of the stock fuel and air stuff, and a turbo and injectors can be swapped quickly later without tearing in too deep.
Old May 27, 2012 | 08:50 PM
BLADE35's Avatar
BLADE35
Plus new fluids and stuff Im thinking 2K budget is going to get Blown out the water
Old May 27, 2012 | 08:51 PM
BLADE35's Avatar
BLADE35
I agree^^^^^with Bryan
Old May 27, 2012 | 08:53 PM
Regulator1988
Do I have to take the cab off to do injectors?
