Oil Cooler just go OEM and order from Clay at Riff Raff Diesel.
Sinister makes a nice EGR delete kit, can order that from Clay at Riff Raff also.
I bought my Coolant filter from Dieselsite, they make a good one.
don't we all.... but i've yet to find anything much on this forum
that isn't pretty much spot on accurate, to the extent that i can
separate fact from fiction.
from what i've observed, it doesn't take that much to make the
stock head bolts go away, and you are looking to put possibly put
bigger injectors on.... and a stronger turbo? without getting the
heads right?
"FTE is an incredible resource - this 6.0L forum can get you the
info on practically anything you need to do."
that's my read on what you get here. the info is second to none.
you are of course free to do whatever you choose, but i'd bet a
cheeseburger that putting bigger injectors and turbo will toast the
head gaskets in a few months.
heads right?
or days.....
I wasn't gonna get a bigger turbo I've just heard that one is better
The Power Max is an awesome turbo for making power. I lost about 2 mpg when first installed it, but im running under 14 sec in 1/4 mile With proper custom tuning the mpg came back.
In your case i agree it would be better for you to do in cab(for studs and injectors)... I am doing a cab off because i am replacing an ***load of stuff and my truck is lifted on top of things. So taking the cab off just makes sense for me instead of spending damn near 30+ hours standing on a bucket and wrestling with things that i can barely reach.
yes lifted trucks are a bit more of a challenge LOL
long way to go when you drop your wrench and have to get down and climb under the truck to get it
I have a Scaffolding I set up for mine
wonder what the time diffrence is Cab OFF vs Cab ON
$15 for an updated HFCM plug.
$25 fuel pressure regulator
$60 Fumoto block plugs
maybe I just dont understand why..
$125 standpipes
I have no idea what this is lol
The first three: Fumoto valves because pulling the block plugs makes doing the chem flushes faster and easier, and so you only have to pull the starter once. The pressure regulator is just the blue spring part of what everyone calls "the blue spring mod", you don't have to buy a kit with a replacement cover, check at RiffRaff for the the cheaper kit. I always reccommend the updated HFCM plug because mine was already corroding on an '07, some guys have this problem and some don't, plus the update lets you drain the water separator without any tools.
Standpipes connect the oil rail the the branch tube in the block. They're prone to leaking, so when you pull the oil rails as part of removing the heads, you replace the standpipes. Your '03 should have the original rails, so you don't need the dummy plugs. Ford Truck Enthusiasts Forums - texastech_diesel's Album: Junk - Picture
You'll need a turbo install kit, and you should search about updating the oil feed line for the turbo because you might have the old braided line that will need to be replaced.
There are alot of options on there
Ecotune Useful if you are just looking for better fuel economy.
Atlas 40 Good if you are looking for more ponies while increasing driveability.
Atlas 80 Okay for short distance and periodic heavy towing, but note that there will be significant overlap between the bennies you are getting out of your ECM tuner.
Hercules Only okay if you plan on never towing heavy.
I wont tow very much and it I do its not often I do drive short distances.... which option should I do?
