Best Injectors
May 28, 2012 | 09:49 PM
If I do all of this is there any extra tools I'll need?
May 28, 2012 | 09:50 PM
Or special things that will help
May 28, 2012 | 09:51 PM
What is your mechanical ability? If you are unsure then your best bet would be to find someone capable, especially if you have a deadline!
May 28, 2012 | 09:52 PM
Quote:
Originally Posted by
jdhart73
Ok so I have already forgotten what your problem is. What exactly is wrong with your truck?
It white smokes at start up and sometimes it won't boost over 5 psi
May 28, 2012 | 09:54 PM
jdhart73
I built my mustang from the ground up... And installed my engine in my f150 after I took out the other one
May 28, 2012 | 09:55 PM
Well then I would say you are likely qualified. Just get your parts ordered ASAP and come on here with questions. Should be good to go.
May 28, 2012 | 09:56 PM
I've never worked on a f250 before. Is it a PIA
May 28, 2012 | 09:57 PM
Nothing is much of a pain in the *** these days with the internet as your sidekick. You will be fine I'm sure.
May 28, 2012 | 09:59 PM
What is the hardest to take off/ do
May 29, 2012 | 09:03 PM
Regulator1988
The back bolt on the turbo can be a bitch so start spraying it now. Rig up some padding over the radiator to lean on. You will need some steps so you can reach. There are some great instructions in the forum.
May 30, 2012 | 08:32 PM
I use heavy painters tarp to lean on when im under the hood. The swiveling gear wrench (10mm?)for that back bolt is a life saver.
May 30, 2012 | 08:35 PM
How can you even spray the back bolts, can't see or barely reach it. Agree with Curts05, ratcheting wrench is a life saver combined with a steel bar.
May 30, 2012 | 08:38 PM
I wish I had that, I rounded that back bolt off.
May 30, 2012 | 08:47 PM
Thats unfortunate. Have to cut it now.
May 30, 2012 | 08:53 PM
jdhart73
How am I gonna cut it
