1978 power steering
Old May 26, 2012 | 03:40 PM
shotgun2's Avatar
shotgun2
1978 power steering
hi
Will a power steering box from a 1978 F350 (6 inline) fit a 1978 f100 (6 inline) side by side, the section with the rag joint is longer by 2 inch. the bolt patter to fit on the frame is the same, it fit.
is there an adjustment on the steering column side?
(and yes i have already paid to have it rebuilt)
thanks
G
Old May 26, 2012 | 04:25 PM
jim collins's Avatar
jim collins
Ford used two different ones,sounds like you have one of each. I don't believe you can move it closer that much , not sure.
Old May 26, 2012 | 04:38 PM
kobaltblue's Avatar
kobaltblue
If the box itself is bigger by two inches the shaft may be a bigger,See if your rag joint flair will fit if it does the steering column could be reworked to fit the new box...It will just be 2 inches closer to ya.
Old May 26, 2012 | 05:02 PM
shotgun2's Avatar
shotgun2
the rag joint is the same. so is the connection to the pitman arm,
just about 2 inch longer, how do i shortened my steering colum?
g
Old May 26, 2012 | 05:15 PM
Action4478's Avatar
Action4478
Try tapping on the rag end , it may slide ...They are 2 piece shafts designed to collapse in a crash (IIRC) ...
Old May 26, 2012 | 05:33 PM
kobaltblue's Avatar
kobaltblue
g
You'd have to break the tack weld holding the mounting bracket and re tack weld in right spot,drill out 2 3/8 to 1/2 inch holes place back into truck find your center mark and tack then remove and weld up....just dont get it too hot well welding.... Not difficult to do if you dont have a welder a muffler shop could do it for a couple of bucks.
Old May 26, 2012 | 05:41 PM
shotgun2's Avatar
shotgun2
you mean the bracket that is on the steering shaft (the one that actually connect to the rag joint) just brake the weld, move it back and reweld it?
G
Old May 26, 2012 | 05:53 PM
kobaltblue's Avatar
kobaltblue
G
The one that holds the column under the dash (where the bolts go) there is noway to shorten the column itself.
Old May 26, 2012 | 08:06 PM
shotgun2's Avatar
shotgun2
hi
i think i just saw the light. you mean under the dash, there is a bracket with about 5 bolts, break the weld, redow the weld, 2 inch closer to the rag joint. all it would do is move the the ENTIRE steering colum toward the driver???
G
Old May 28, 2012 | 05:23 PM
Action4478's Avatar
Action4478
Is this one that has the steering unit back near the firewall ?If it is I' am all wet ....
Old May 29, 2012 | 07:30 AM
jim collins
You got any pictures, it will help us to help you ? The column can be shortened if it don't have a shifter arm or arms at the lower end,i have done it.
Old May 29, 2012 | 07:40 AM
shotgun2's Avatar
shotgun2
Good morning.
well, it work, i moved the bracket under the dash. move the steering column closer to the driver. I also needed to cut the 1 1/2 inch off the steering column. (then rewleded the bracket.
So far so good everything is working. thank you everyone.
(when i figure out how to put picture in my post I will had some.)
Now , to power brake.
G
Old May 29, 2012 | 08:48 AM
kobaltblue's Avatar
kobaltblue
Glad you got it fixed, I just used a 91 Power booster on mine holy crap does it STOP NOW! bUT YOU NEED TO HAVE WELDING AND FAB SKILLS TO PULL THIS ONE OFF...
Old May 29, 2012 | 08:53 AM
shotgun2's Avatar
shotgun2
all the parts i got are from a 1978 F350.
power steering box, pump, bracket, cooling rad = $20
power brake booster = $20
lots of sweat, curse, beer, burn. = free (maybe not the beer)
when the ##$%%^%^ finally worked last night, priceless.
G
Timothy R. Wyatt
Mar 21, 2017 08:38 PM
94matt
Apr 3, 2004 09:40 PM
6677ebman
Aug 13, 2003 11:14 PM
70highboy
Jan 20, 2003 07:30 PM
Huggy Bear
Feb 23, 2002 08:28 AM
