power steering
Old Jan 19, 2003 | 11:44 PM
70highboy's Avatar
70highboy
power steering
i have a 70 ford with manual steering and i was wondering if someone knew of what trucks i can directly bolt the power steering front end in from?
Old Jan 20, 2003 | 08:30 AM
1968F250LWB's Avatar
1968F250LWB
power steering
73-79
Old Jan 20, 2003 | 11:52 AM
sparky2a
Guest
Posts: n/a
power steering
Actually I think 67-79 will fit as long as it is from the same Series aka F100, F150, F250, F350......
If possible get the setup from a truck with the same engine, then the pump and brackets will fit for sure.
Also, on the FE engine anyway, you will need the drivers side engine tower. The "new" steering box will hit the old tower, unless you do a little grinding
Oh yeah the steering column is a different length so grab that too.
Sparky2a (formerly Sparky )
Old Jan 20, 2003 | 07:30 PM
mk's Avatar
mk
power steering
The steering box is actually the same on the heavier trucks if it's the Ford box(two bolts on the top cover). The power steering column is four inches shorter and you'll need the bracket on the firewall with p/s stamped on it for the different column angle. As Sparky said, all 67-79 trucks could be potential donors, best if you can get it all off one truck.
mike
