New guy from SC
Old May 28, 2012 | 11:52 AM
Landis79's Avatar
Landis79
New guy from SC
Hey everyone, new guy from the Charleston area. This is my 1979 ford F100 and it has a 302 with a three speed. This is going to be a learn as I go project, so I will probably have lots and lots of questions; however, it looks like this is the place to be for help. I'm looking forward to getting started.
Old May 28, 2012 | 12:01 PM
CalebJns's Avatar
CalebJns
Very Nice...Welcome to FTE! The BEST place for information, and help!
We love pics of your truck and your work/progress...let us know what your planning on doing to your truck...the most important thing to remember is...it is YOUR truck, do what YOU want!
Congrats, and Welcome Aboard!
Old May 28, 2012 | 01:48 PM
GLR's Avatar
GLR
Welcome to the site. It's not your fault you're in CS. Just kidding, we go down to Clemson-Salem area once in a while to see friends.
Lots of info here, like what seats will fit etc. Like Caleb says fix it the way you want it.
You might also join the SC Chapter to hook up with other FTE'rs in the area.
Join Chapter that didn't work. If you go to SC chapter there is a link there for joining.
Old May 28, 2012 | 02:03 PM
SC'79's Avatar
SC'79
where in charleston are you located? im in charleston too downtown but working down near edisto 1979 f150 ranger bright orange.
Old May 28, 2012 | 03:02 PM
Landis79's Avatar
Landis79
Caleb- My plans for the truck at the moment is to get in running good. It runs, but I just want to update some things to get it roadworthy.
GLR- Thanks for the info, i'll look into joining.
SC79- I'm in summerville. I'm originally from missouri, but I'm in the Air Force and I'm stationed in Charleston.
Old May 28, 2012 | 03:19 PM
CalebJns's Avatar
CalebJns
It looks pretty good (from the pics)...body appears to be pretty straight...there are some things you can do to the ole 302...couldn't really tell from the pics, but you can put an aluminum intake on it, if you have a 2bbl currently you can update to a 4bbl...plugs, wires, fluid flush, one thing leads to another...but it is a lot of fun!
Looks like you have rims from a 90's era...looks good though...
give us a little more info on the engine, transmission, exhaust, etc...
Old May 28, 2012 | 05:48 PM
Landis79's Avatar
Landis79
Well like I said it is a 302 with a three speed. The guy I got it from said it was originally a three on the tree, but he moved it to the floor. I'm still really new so I'm not sure what kinda of transmission it is. It has a holley 2 bbl on it right now. I also have a motocraft 2 bbl that came with it. Everything else motor wise is stock. It has dual exhaust with glass packs. No power brakes. It does have power steering, but it doesn't work. Maybe needs a new pump, i don't know.
The body is in ok shape. It has dings and some small dents, but not to bad for being on a farm most of its life.
Old May 28, 2012 | 06:01 PM
CalebJns's Avatar
CalebJns
If you really want to "spice" it up, get you an aluminum 4bbl intake like an Edelbrock. Put a New 4bbl Carb on it. In my opinion (take it for what its worth), I like the Edelbrock...(again to me) they are more like an everyday driver type, set it and go; as opposed to the Holley, which is more of a performance type, tweaking here and there...
As for the PS, make sure the belt is hooked up, and it has fluid...a quick and easy check may save a few bucks (having to buy a new pump).
Just be cautious...once you get started, it is so hard to stop...they are so much fun to work on and tweak!
Old May 28, 2012 | 06:11 PM
montana_highboy's Avatar
montana_highboy
That 302/3spd combo should yield some pretty decent mileage.
Old May 28, 2012 | 07:21 PM
GLR's Avatar
GLR
Don't forget headers. I'm going to put a set of Mustang shorties on my 79 302 auto.
Old May 28, 2012 | 11:06 PM
79CAMOFORD's Avatar
79CAMOFORD
Welcome aboard the FTE train!! Good looking truck too! what you do in the AF,I'm currently stationed in Montana
Old May 29, 2012 | 04:15 AM
Landis79's Avatar
Landis79
Thanks 79camoford! I'm in CE. I run heavy equipment.I also do runway and road repairs.
Old May 29, 2012 | 05:08 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Welcome to FTE
Ford type 3.03 3 speed manual all syncromesh transmission, standard equipment in 1963/83 F100's and 1975/86 F150's / Warranty Plate TRANS code: C
Thank you for serving.
Old May 29, 2012 | 06:30 AM
79CAMOFORD's Avatar
79CAMOFORD
OK, I'm SF!! I don't mind it here in MT cause I'm 100 miles from home but I would like to get out of Montana
Old May 29, 2012 | 08:17 AM
NumberDummy
Sign on the ND/MT border: Custer was safe till he rode into Montana.
