my new project
Old Jan 12, 2013 | 06:18 PM
  #61
ReBilld's Avatar
ReBilld
When you get yours rebuilt, I'll send you mine! LOL!!
Old Jan 12, 2013 | 08:11 PM
  #62
oldbird1965's Avatar
oldbird1965
Riffraff Diesel: Ford Overhaul Kit
  #63
oldbird1965
Then you freshen up the Mule.
Old Jan 12, 2013 | 08:17 PM
  #64
fordman67's Avatar
fordman67
Sure fellas.i actually enjoy building engined,trans,rear ends.that type of work is a lot of what I did at the dealership.
Old Jan 12, 2013 | 08:26 PM
  #65
glovemeister's Avatar
glovemeister
That kit looks pretty sexy. Represents another 350k miles or more.
Old Jan 12, 2013 | 08:33 PM
  #66
fordman67's Avatar
fordman67
Originally Posted by oldbird1965
Well,I must just be dumb. I may call mon and see about undersize bearing options.I also found that ford does sell cam and connecting rod bushings.gonna be a big list.I wonder if melling ho lpop is better than new ford lpop.it will be getting a good set of sticks for sure before it ever goes in...
Old Jan 12, 2013 | 08:51 PM
  #67
fordman67's Avatar
fordman67
That is exactly my goal.anything that can be fix ed,rebuilt,replaced will.my goal is half a million more!
Old Jan 12, 2013 | 10:11 PM
  #68
oldbird1965
Clay sells the Riffraff Diesel: Melling M208 Low Pressure Oil Pump LPOP but I don't know if the motorcraft is better or not?
Old Jan 13, 2013 | 11:41 AM
  #69
fordman67's Avatar
fordman67
That is a big question for me.I thought the melling lpop was a high output unit.I just did some study,It seems it is a bit better.with the t500 I would think supply being up to muster woul be important as well. The one that is with it presently sure seems wore out. Does anyone have the spec for outer rotor to housing clearence.IF it were for a trans I would be amazed it still did anything.THe outer gear does not show any real abnormal wear but its LOOSE in the housing.I will post a pic later,IT is SO obvious.Thinking I may have found why the engine was swapped out of the truck.Sure would be funny if that was all that was wrong with it...
Old Jan 13, 2013 | 11:11 PM
  #70
fordman67's Avatar
fordman67
Well,I just emailed Clay.The motorcraft kit has no provisions for undersize main or connecting rod bearings.Darn,OH well.We will see what needs to happen when I get that far. Good news is cam bearings are included.
Yet another twist now.I was cleaning up parts this afternoon.I cleaned up among other parts the hpop hoses.WELL I was looking on riff for hoses and come to find out my hoses match the e99 hose set? the dang VC said 2000...Wish I knew how to decode the engine serial #...
Old Jan 13, 2013 | 11:44 PM
  #71
oldbird1965
Sounds like that change over year is going to give you headaches.
Old Jan 13, 2013 | 11:47 PM
  #72
fordman67's Avatar
fordman67
I had hoped something in my life would be easy..oh well..maybe i wont get soft...
Old Jan 14, 2013 | 02:37 AM
  #73
95_Dually's Avatar
95_Dually
I am jealous Aaron. I want to build a 7.3 as well. Watching your build intently.
Old Jan 14, 2013 | 11:47 AM
  #74
fordman67's Avatar
fordman67
Awww dont be.its gonna be lots of work and expensive.but in the end it will be SO worth it to keep my good ol gal kicking.
Old Feb 22, 2013 | 09:36 PM
  #75
fordman67's Avatar
fordman67
well,got the block back from a good cleaning. Its at the machine shop along with the crank. Now I just have to run the heads down to the dealership and use the inj sleve removal tools and brake the heads down to see what we have there.
I would post up a pic of the clean block but i cant get it to load to photobucket for some reason.
