SENSOR BY OIL FILL...
Old May 20, 2012 | 01:34 PM
75highboy390's Avatar
75highboy390
My sensor on top of the engine by the oil fill neck is leaking oil through the two wires extending out the end. Which sensor is this. Oil temp? Press? I looked up numerous sensors online and none look like this one. I need to swap it out for new to fix the oil leak. Thanks guys.
Old May 20, 2012 | 01:37 PM
johnboggs21's Avatar
johnboggs21
That the sensor for your tach. I believe you can only get that one at IH or Ford, when I replaced mine it was about 80 dollars.
Old May 21, 2012 | 01:00 AM
akamacgyver's Avatar
akamacgyver
Clueless spectator!
Boggs is right, that is your tach sensor. It is a dealer only part. Shop around though, I got dealer prices as high as 92 bucks, and ended getting one at a dealer in Madera CA. for 51 dollars.
allhuntalltime
May 3, 2013 06:52 PM
meier63
Jan 25, 2011 07:32 PM
mudbug04
15
Jul 16, 2009 03:48 PM
brad7.3
Aug 20, 2006 09:37 PM
teg3
Aerostar
Jun 16, 2004 01:18 PM
