oil leak
Old Apr 14, 2013 | 11:51 AM
allhuntalltime's Avatar
allhuntalltime
oil leak
What is the sensor on the front of the drivers side head that can leak oil so bad at the o ring and where can you get an o ring for it.
Old Apr 14, 2013 | 12:42 PM
LSO1123's Avatar
LSO1123
ICP sensor. DieselOrings
Old Apr 14, 2013 | 06:12 PM
Brother Les's Avatar
Brother Les
pull the connection off. If there is oil in there, it is not the o-ring, but the ICP sensor. You will need a new one.
Injection Control Pressure Sensor 1999-2003 ICP Sensor
Old Apr 14, 2013 | 06:34 PM
MTDewX's Avatar
MTDewX
Riffraff has them for $140 too
Riffraff Diesel: Motorcraft ICP Sensor 97-03
what are these sensors life span? I might have to take mine out and look at it to see if there is oil in there. when you say oil in side the sensor, does that mean when you take the sensor out in your hand and see oil in the actual sensor or the hole it came from?
Old Apr 14, 2013 | 06:48 PM
Christof13T's Avatar
Christof13T
No.
Just unplug the electrical connector. Look down in the sensor's connector socket for oil.
Look on the end of the pigtail connector for oil.
If present... i clean thoroughly with electrical contacts cleaner... plug it back in... then check again after driving for a while.
Well...
I used to.
Now i just plug in AE.
Old Apr 14, 2013 | 11:53 PM
MTDewX's Avatar
MTDewX
Originally Posted by Christof13T
No.
easier said than done. I can't get my head any farther than over the fan blades. (van)
but I will give it whirl with a mirror as my HPOP and fuel bowl are waiting to go back in once the snow stops.
thanks for the explaination
Old May 3, 2013 | 01:26 PM
grec-o-face's Avatar
grec-o-face
I replaced my ICP sensor about 18 months ago after having drive-ability issues and finding oil in the connector.
Now there's oil in the connector again.
So, as far as "life span" goes....
Old May 3, 2013 | 06:52 PM
srteach's Avatar
srteach
If there is oil coming from around the threads, the oring is inexpensively available from the nearest Ford dealer as part F4TZ-9N693-A or equivalent. If this is the problem, there will be large amounts of oil loss, so change all the oil galley orings (HPO oil hoses, sensor ports, etc.).
I tried to use a typical oring to seal up the oil galley leaks, but they don't hold up to the pressure. leakage stopped when I used the reinforced Ford orings.
bama29fan
Aug 8, 2011 12:00 AM
tigwelder
Jan 26, 2011 09:21 PM
meier63
Jan 25, 2011 07:32 PM
StampedePSD
Dec 8, 2008 02:36 PM
brad7.3
Aug 20, 2006 09:37 PM
