Sensor covered in oil
Old Jul 15, 2009 | 03:15 PM
mudbug04's Avatar
mudbug04
I dont know what this sensor is but it is covered in oil and my buddy doesnt know what it is called but said it is not supposed to have oil in or on it. It is located on the driver side of the block on top near the front directly inside the valve cover.. does anybody know what it is and what its function is and does it need to be replaced?
Old Jul 15, 2009 | 03:20 PM
superduty4x4's Avatar
superduty4x4
ICP sensor, and if it's got oil inside the electrical connector it needs to be replaced.
Old Jul 15, 2009 | 03:24 PM
Layson's Avatar
Layson
Its toast... replace it like Chase said
Old Jul 15, 2009 | 03:25 PM
mudbug04's Avatar
mudbug04
what is it and what does it do? and i have to say thank you chase you have been extremely helpful for me today... i hope everybody is as nice as you. i appreciate it.
Old Jul 15, 2009 | 03:38 PM
superduty4x4
ICP stands for injection control pressure... and I always forget exactly what it does but its related to the high pressure oil system used to fire the injectors.
Old Jul 15, 2009 | 03:46 PM
mudbug04's Avatar
mudbug04
ok so is it hard to change is there anything special i need to do or is it just a matter of pulling it out and putting a new one in?
Old Jul 15, 2009 | 03:52 PM
superduty4x4
Never done it before, but as far as I know you just unplug, spin the old one out with a wrench, put the new one back in, and plug 'er in.
Old Jul 15, 2009 | 03:57 PM
mudbug04's Avatar
mudbug04
i hope ur right i'll try that when i get off work, nothing ever goes that easy for me haha, i usually wind up with a big hammer
Old Jul 15, 2009 | 04:04 PM
fifthwheel01's Avatar
fifthwheel01
ICP is a piece of cake. just pull off the connector (gently) get some electrical connector cleaner, spray it down real good to get all the oil residue out/off the connector, unscrew the old one you might need a 5/8 crow ft if I remember right. put in the new one and replug. It's the first thing i did to my F250.
Old Jul 15, 2009 | 04:11 PM
mudbug04's Avatar
mudbug04
thank you john, and thanks again chase
Old Jul 15, 2009 | 07:21 PM
F350-6's Avatar
F350-6
Like they said, it's an easy change. Unplug connector, use a crows foot wrench to remove the old one, the new one is a different design so you can use a big socket to install it, then plug the connector back in. The spec calls for 21 ft - lbs putting it back on. Don't overtighten it, you don't want to crack anything.
The ICP reads the oil pressure in the heads. It provides this reading to the PCM so it can adjust the IPR as needed to provide proper pressure to the fuel injectors for the load demanded by your right foot.
Old Jul 15, 2009 | 08:31 PM
F-250 Super Duty's Avatar
F-250 Super Duty
Is this something that should be changed out after a few years or just let it right? What's the price tag on one of these?
Old Jul 15, 2009 | 08:59 PM
F350-6's Avatar
F350-6
I changed mine at around 280,000 miles because I noticed it starting to leak a little bit and already had purchased a spare just in case. Don't remember the cost, but I wouldn't mess with it until there are some signs or symptoms of an issue.
Old Jul 16, 2009 | 06:22 AM
mudbug04's Avatar
mudbug04
well sirs the ford place wasnt answering phones anymore after 430 so i didnt get to change it anyway... any after markets or just ford?
Old Jul 16, 2009 | 10:10 AM
zx250's Avatar
zx250
Of the next Riffraff East
Stick with OEM on sensors. Ford has them and they like them. You can find them on Ebay sometimes and I think Bob at Diesel Orings has them.(link in sig).
