Overdrive Indicator Light
Old May 19, 2012 | 04:57 PM
dezridin2's Avatar
dezridin2
While on vacation, the light on the gear shift selector that indicates if you are in overdrive, started flickering. It is a 1993 E350 motor home with a 7.5 and a E4od trans. Has anyone had this problem?
Old May 19, 2012 | 06:17 PM
Franklin2's Avatar
Franklin2
Flickering is one thing, blinking with what seems to be a pattern could be a error code from the computer that controls the tranny.
Old May 19, 2012 | 07:21 PM
projectSHO89's Avatar
projectSHO89
Usually, it's a rhythmic blinking (steady rate) that indicated your vacation plans are going to include a visit to a transmission shop....
The TCIL does not attempt to communicate fault codes, those must be pulled via the OBD1 port.
If it's just randomly flickering or blinking, you probably have a wire rubbing through at the base of the shifter lever and it's shorting out, especially if you aren't noticing any transmission-related symptoms.
landcruzr
Dec 24, 2009 08:59 PM
Davey F150
Jun 7, 2009 05:51 PM
deanzawistowski
Apr 4, 2008 06:15 AM
jbondi
1978 - 1996 Big Bronco
42
Sep 30, 2004 01:31 PM
NSTAG8R
Jun 24, 2004 04:14 PM
