96 F250 Codes
Old May 16, 2012 | 09:13 AM
kevin g's Avatar
kevin g
96 F250 Codes
My 96 F250 is a OBD1 (plug under the hood). I just got the codes 33 and 133 and I am not sure what they mean. I think 33 = EGR valve and I can not find 133 anywhere. Does anyone know what these codes mean?
Old May 16, 2012 | 09:44 AM
rla2005's Avatar
rla2005
Your truck should have all 3 digit codes not a mix of 2 and 3. I suspect you are misinterpreting your results. I bet you are getting the all clear code of 111 then a repeat of the same 111. There is a separator flash before the PCM goes into the CM code display, that is your 1 "code". Your next display is once again the all clear code (111 - 111).
Old May 16, 2012 | 10:03 AM
kevin g's Avatar
kevin g
Thanks, I think you are right. I just watched the flashes on a youtube tutorial and it was as you said. Only problem now is I am back to where I started from. The truck starts and runs good for a few seconds and then gradually declines into a rough idle and then cuts off. I can keep it running (very rough) if I continue to feather the throttle. Not sure what to try next.
Old May 16, 2012 | 11:34 AM
rla2005's Avatar
rla2005
Verify the fuel pressure with a gauge mounted on the fuel rail test port. Should maintain 32-45 PSI for a V8 engine. 4.9L I6 is in the 50-60 PSI range IIRC.
Also check to see if you are losing spark, pull a plug or use a tester on one of the plug wires. You should have a nice blue colored spark.
One of those two are dropping out.
Old Sep 21, 2014 | 07:31 PM
Duncansm's Avatar
Duncansm
Can anyone expand on this? I'm having the same issue.
Old Sep 22, 2014 | 10:25 AM
rla2005's Avatar
rla2005
Did you check the fuel pressure?
Did you check for spark?
1911fan
6.7L Power Stroke Diesel
Jul 24, 2017 10:33 AM
OBSGuy45
Apr 5, 2016 12:00 AM
boggerted
May 25, 2009 10:54 AM
DJdemon6696
Jan 26, 2007 02:27 PM
johhan
Nov 2, 2004 06:38 AM
