Got some codes to fix...
Old May 24, 2009 | 09:46 PM
boggerted's Avatar
boggerted
I pulled codes on my 89 F350 to try and diagnose my lack of power. I did plug wires, cap and rotor to try and remedy the problem and it made a good bit of difference, but it still feels like i=s either running rich or missfiring. I got codes 33 and 129. What do these mean? I think 33 has something to do with the EGR, but I dont know what to do to solve these issues. thanks
Old May 25, 2009 | 04:38 AM
Lazy K's Avatar
Lazy K
I`m no expert but I think you need to check again. As far as I know your codes should all be two digit.
Old May 25, 2009 | 04:54 AM
andym's Avatar
andym
Yes, you can never have two- and three-digit codes. Read them again or buy a code reader.
Old May 25, 2009 | 10:34 AM
boggerted's Avatar
boggerted
ok then the 129 is code 29. I just thought that code wasnt applicable because it deals with the vss and my speedo works fine.
Old May 25, 2009 | 10:54 AM
Conanski's Avatar
Conanski
33 is EGR valve opening not detected. Check the vacuum lines first, then test the valve to see if it moves with vacuum and that the output of the position sensor changes as expected. If all that checks out the EVR may be the problem, it's the solenoid over by the coil that controls vacuum to the valve.
Bad Bad Leroy Brown
17
May 20, 2013 03:42 PM
ChristopherN
18
Dec 29, 2011 09:56 PM
boggerted
Feb 11, 2010 01:44 PM
fmrplt
1983 - 2012 Ranger & B-Series
Mar 1, 2008 05:45 PM
IES
May 2, 2003 11:57 PM
