Overdrive problem
Old Jul 1, 2011 | 11:28 PM
Fatcatpaddy's Avatar
Fatcatpaddy
Overdrive problem
I recently took my 1992 Ford F-350 7.3idi auto on a 850mile road trip last week. I noticed when driving 70-75 in overdrive down the highway I noticed the rpms were jumping up from 2300rpm to 2500rpm (pulsing every min or so for a second) when I backed the speed down below 70 the problem when away. What could be wrong I checked the trans fluid and everything was ok.
Old Jul 2, 2011 | 12:09 AM
David85's Avatar
David85
Welcome to the forum.
First thing to do if you can is check for fault codes. Being a 1992, it *should* flash the overdrive light at you if a code has been stored.
How does your speedometer and tachometer read? They have to be rock steady or the E4OD computer will have problems.
Old Jul 2, 2011 | 12:28 AM
Fatcatpaddy
I don't think the overdrive light works any more because there is never light from it. What do you mean the gauges have to be rock steady? If you mean the throttle being steady I was using the cruise control. The transmission has 120k on it rebuilt 40k ago.
Old Jul 2, 2011 | 01:05 AM
David85's Avatar
David85
I meant your speedometer needle and tachometer needle need to read steady when the truck is driving.
Old Jul 2, 2011 | 01:12 AM
Fatcatpaddy
Yep they are reading steady while driving I can defiantly hear the trucks revs jump while driving, when I get back in town (currently on road trip with it) on tues I will try to scan for codes. I was thinking possibly the torque converter would be causing that?
Old Jul 2, 2011 | 01:44 AM
David85's Avatar
David85
Yes, thats most likely what you are seeing. Usually its a sensor error that causes the problem (such as speed sensor, or tach sensor). In some cases, bad grounds in the tail lights can also confuse the transmission since its supposed to unlock the converter instantly as soon as you touch the brake pedal. If the problem persists, it may go into limp mode (hard shifting). I'd get a code scan done ASAP.
Old Jul 2, 2011 | 08:38 AM
Fatcatpaddy
Do you recommend I buy a scanner or should I pay the shop to scan it?
Old Jul 2, 2011 | 09:15 AM
Lazy K's Avatar
Lazy K
Ford Fuel Injection » How To Run a Self-Test Here is a link on how you can get any trouble codes yourself. Or you could buy an Equus 3145 code reader for around $30.00 to make life easier.
During the test you will need to keep the gas pedal to the floor (engine off) otherwise you may get a false TPS code.
Old Jul 2, 2011 | 11:21 AM
Fatcatpaddy
I bought the scanner. I started the truck this morning to find the tach was completely dead. After I took off it came back but at an idle the tack is jittery.
Old Jul 2, 2011 | 11:39 AM
FORDF250HDXLT's Avatar
FORDF250HDXLT
you'll want to change the tach sensor/and or repair the wires before you continue to drive the truck.otherwise it could needlessly cost you thousands for a rebuilt trans/hundreds for a used one,AND you'd still need a working tach after trans replacement anyway.
Old Jul 2, 2011 | 12:13 PM
Fatcatpaddy
I will be careful today if it starts to mess with the truck I will stop, but I want to get back to California before I look into it.
Old Jul 2, 2011 | 06:21 PM
Fatcatpaddy
500miles done today another 500 to do on Tuesday the truck is working great but I will still fix the problem in California
Old Jul 5, 2011 | 05:52 PM
Fatcatpaddy
got code reader, truck had no codes but im changing tach sensor.
noj70
Dec 2, 2017 03:15 PM
lawmac2005
Dec 9, 2010 05:56 PM
Gr8ride
Oct 19, 2009 10:25 AM
SShank42
Bronco II
19
Jan 11, 2007 12:34 PM
G-Bone
Feb 15, 2006 07:02 AM
